Ouch for the polic that is
![]() 2011MY 110 XS USW Black |
^^Oops! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
They were very apologetic and a bit embarrassed I think, but we both got away without a scratch.
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
not good! which roundabout, I'll be sure to avoid it
![]() CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
Oldcraighall, joining the city bypass to the A1
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1458 ![]() ![]() ![]() |
Was 'Rubbed' up by white van man
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
He quite fancied his luck anyway........... Till I got out
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Broke the N/S door mirror on a big branch sticking out of a hedge this morning. Did'nt see it in the dark.
hmm, they must have been concentrating on something else, fairly straightforward junction & not too blind. I used mine to get to a 4x4 response team meeting this evening, windy & wet it was too. Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Been busy, sprayed the checker plate black on the side steps, as everything else is black it looked odd to me.
Then pre-wired the new fuse block for the, fog lights, heated mirrors and Scangauge II. Also sprayed the new Puma Pod from Mud UK black ready for the Scangauge. Also removed the mirrors, fitted the heated elements and drilled out the mirror arms and pre-wired them. If the weather improves tomorrow then I'll fit the mirrors and complete the internal wiring. Will post a few pictures tomorrow. _______________________________ Puma Defender 90 |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
My ECU interface from BAS arrived so remap now complete. What a difference! .. Looking forward to my drive to work.
Pete at BAS was great and put up with me cocking things up by being a bloke and not reading the instructions ![]() All good now .. Intercooler next. 2008 Defender 110 XS SW - M57N2 / 8HP70X |
Pictures of newly painted side steps and part of the wing mirror assembly prior to refitting.
Before painting. ![]() Click image to enlarge After painting. ![]() Click image to enlarge A couple of pictures of the mirror arms; Picture of cables routed through the spring. ![]() Click image to enlarge Ball joint ![]() Click image to enlarge Complete arm. ![]() Click image to enlarge I'll post more as I progress today. _______________________________ Puma Defender 90 |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Put my steering damper back on after it fell off while I was parking up at work
![]() The fixing at the chassis end looked like it had undone itself, and let the damper swing down onto the steering guard, as it was still attached at the other end. Fortunately, all the cup and plain washers, bushes, and one of the nuts were still present laying on the steering guard, so I only had to find one nut. Fortunately I had one in an old box of bits at home, which was good as I don't know where you'd buy one of these from, as they're an odd size. Pete |
