Home > Maintenance & Modifications > Safari Equip Single Swing Arm
CarlinAbz
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
My single arm wheel carrier arrived a few weeks ago from Safari Equip but with no fitting instructions, has anyone here fitted one or have the instructions? I have emailed the guys at Safari Equip but no response, I'll try calling them again. There are two additional fitting plates and I am trying to figure out where they should go on the cross member. Help much appreciated.
Post #279396 4th Nov 2013 5:29pm
leeds
Give me a ring and I will do my best to talk you through the fitting of it.
Brendan
Post #279447 4th Nov 2013 7:36pm
bob neville
Same carrier Thumbs Up
http://www.extreme4x4.co.uk/acatalog/LRM_i...arrier.pdf
2013 Defender 90 CSW - sold
Post #279449 4th Nov 2013 7:39pm
CarlinAbz
Brendan
Thanks...travelling in Middle East this week but will call next week. Thanks very much for your help. Very much appreciated.
Post #279473 4th Nov 2013 8:21pm
CarlinAbz
Bob,
Thanks....between your info and Brendan I should now have no excuse not to get outside and fit the carrier. Thanks to all
Post #279476 4th Nov 2013 8:23pm
K9F
All you need to know. With pictures.... Thumbs Up
http://www.defender2.net/forum/topic18175....swing+away If you go through life with your head in the sand....all people will see is an ar5e!!
Post #279477 4th Nov 2013 8:24pm
leeds
There was me thinking it was the single pivot, multi height wheel carrier rather then the standard swing away wheel carrier Embarassed
Between that article and any phone call we should be able to sort it out.
Brendan
Post #279480 4th Nov 2013 8:31pm
CarlinAbz
It is the single swing arm.....I will definitely call you next week if the offer still stands Thumbs Up
Post #279482 4th Nov 2013 8:37pm
bob neville
I thought it was the other one Embarassed
K9's link gives you a good idea of how to fit the one you have Thumbs Up
Post #279487 4th Nov 2013 8:46pm
CarlinAbz
No worries...great that folks are willing to give up time to help. I will have loads more questions as will be fitting the XS out for an expedition over the Pyrenees in May. New to off-roading so will have a lot of questions for you guys.
Post #279491 4th Nov 2013 8:57pm
leeds
If you do not know the answer there is no such thing as a daft question!
So just ask away.
Brendan
Post #279513 4th Nov 2013 9:34pm
K9F
Of the two backing plates that have been supplied the shorter one is for the 90 the larger one for a 110 as the crossmembers are different and the longer will not fit unless you take a grinder to it. If you need any crushcans/spacers 'pm' me I got loads spare. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #279569 4th Nov 2013 11:14pm
