![]() | Home > Technical > Clutch plate |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
The Puma doesn't have a Dual Mass Flywheel, the Td5 did. This might be useful -
http://www.defender2.net/forum/topic13662-15.html ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18026 ![]() ![]() ![]() |
If your Defender is an 08 Puma as your profile suggests, then you already have a solid flywheel, they all do. There was a number of issues with early clutches (springs falling out of the driven plate) and you may have had problems, but the current plates seem to be OK.
Edit: beaten to it again! |
