Home > Off Topic > Grade of steel for bike rear dropouts?
ZeDefender
Hi all
Does anyone know from what grade of steel bike rear dropouts are made? I have to make and braze on my own Sad
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #278290 31st Oct 2013 3:52pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
you can cut them out of plate but it will have the same problem as your current dropouts. The Axle in a geared hub naturally wants to rotate and if free to do so will chew away at the metal. A cast dropout or something replaceable would be your best bet in the long term.
Ceeway (http://www.framebuilding.com) have a huge range. Or have a look and some of the Paragon works dropouts. www.td5.org
Post #278335 31st Oct 2013 6:41pm
Orangeboy
You can use the anti rotate washers that shimano and the like sell
To keep everything in place
Post #278339 31st Oct 2013 6:45pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
If you made your own you could make a screw on replaceable section on them where they wear. I think most originals are drop forged.
Post #278388 31st Oct 2013 9:11pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Ragley or nuke proof for me
Post #278426 31st Oct 2013 10:42pm
Cakey
Steel Ali or bronze
Post #278430 31st Oct 2013 10:47pm
ZeDefender
Many thanks for the advice guys.
I have anti-rotation washers that came with the SRAM hub (geared and braking) - hence the new direction for the slot. However, I'm worried that plate won't be hard enough on a torqued-up tandem, even for them.
Ceeway look promising (great link) and I'll check out Ragley and Nukeproof as well tomorrow.
Bow down Bow down Bow down
Matt Tell someone you love them today because life is short.
Post #278443 31st Oct 2013 11:03pm
ZeDefender
Forgot to say - that was my idea too, until I realised the middle chainstay join had cracked (see photo), the whole structure was weak and I should replace the whole thing Big Cry
Cheers Thumbs Up
Post #278445 31st Oct 2013 11:06pm
