![]() | Home > Off Topic > Grade of steel for bike rear dropouts? |
Hi all
Does anyone know from what grade of steel bike rear dropouts are made? I have to make and braze on my own ![]() [URL=] ![]() Click image to enlarge[/URL] Cheers Matt Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
you can cut them out of plate but it will have the same problem as your current dropouts. The Axle in a geared hub naturally wants to rotate and if free to do so will chew away at the metal. A cast dropout or something replaceable would be your best bet in the long term.
Ceeway (http://www.framebuilding.com) have a huge range. Or have a look and some of the Paragon works dropouts. www.td5.org |
Orangeboy Member Since: 24 Sep 2013 Location: Uk Posts: 48 ![]() |
You can use the anti rotate washers that shimano and the like sell
To keep everything in place |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
Ragley or nuke proof for me
Steel Ali or bronze |
Many thanks for the advice guys.
I have anti-rotation washers that came with the SRAM hub (geared and braking) - hence the new direction for the slot. However, I'm worried that plate won't be hard enough on a torqued-up tandem, even for them. Ceeway look promising (great link) and I'll check out Ragley and Nukeproof as well tomorrow. ![]() ![]() ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Forgot to say - that was my idea too, until I realised the middle chainstay join had cracked (see photo), the whole structure was weak and I should replace the whole thing ![]() Cheers ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
