AlexPuma42 Member Since: 13 Jun 2013 Location: Manchester Posts: 43 ![]() ![]() |
not technically today but last night had to pull a motor out of a very boggy field - tyres disappeared into the mud and was drastically trying to get grip - the motor i was pulling out had flat tyres so that didn't help but the land pulled through after engaging low ratio and diff locks, the land i spent 5 hours cleaning on sunday is now caked in mud the joys of land rover ownership 110 Hard Top - Izmir Blue
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Still trying to sort out my abs. ECUtesting.com declared it unrepairable so got another one from equicar. Should be here tomorrow and fitted at the weekend. Can't wat to be free of those three lights
Got halfway across an awkward road junction this morning when there was a dull thud and no forward motion. Quick engagement of the diff-lock and went on to where I was going, only another mile up the road. I was thinking half shaft, CV joint but luckily it was the teeth stripped out of a rear drive flange. I'd replaced two on the back about 6months ago and it was one of those, bit of a
Lucky, when that happened to me it was the front diff
Good luck,let us know how it goes. Back O/T. Dinotroled the INSIDE of the battery box,coz I were bored and had nowt to do and it were starting to get a bit scabby. |
I fitted the HD jobbies a while back, I better be careful about those Br*tpart halfshafts I just fitted,eek.Plan to get Ashcrofts next year when funds allow. |
Fitted new steering box arm and ball joint and the weather actually stayed dry for me
Vizsla Member Since: 18 Nov 2012 Location: Berkshire Posts: 96 ![]() ![]() |
Fitted my new bonnet security hinges today (thanks again Brendan)
Very pleased with the finish on the hinges and they fitted without any need to adapt the bearings as they fitted in the curl hinge without any problems. Additional Silkaflex and ball bearings and now far more secure than the original fittings. Yesterday I fitted the new locking cubby box (thanks Matt). Very pleased with the finish on this too and its much more substantial than the old OEM box ![]() Great service from both 4x4 Overlander and FCX respectively ![]() ![]() |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Took it for a wash to the local UN cleaning station, normally a great job, but today just okay.....so washed myself again when I got home, then decided as I was bored I'd polish it as well. _______________________________
Puma Defender 90 |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
Decided it was time for the winter wheels
![]() ![]() Click image to enlarge ![]() Click image to enlarge DEFENDER XS UTILTY 110 AUTO ONLY ACCURATE GUNS ARE INTERESTING Last edited by foxkilla on 1st Nov 2013 4:16pm. Edited 2 times in total |
Thank you for the business vizsla, I'm glad you were pleased
![]() Happy to give you £40 for your old cubby if it is a genuine XS one |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
Fitted Crystals and OSRAM Nightbreaker Ultimate bulbs .. just waiting for it to get dark
![]() Ordered Remap interface from BAS Auto Services. 2008 Defender 110 XS SW - M57N2 / 8HP70X |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
Notice my clutch Master Cylinder is leaking...again. So ordered a genuine LR one. £72 + VAT! now I need a dry weekend to do the job in-between, decorating, testing radios for the rally, dialling into works servers to make sure all is well and removing floor boards. 1999 Defender TD5 110
Etched my LED headlights using the ISR etching kit and fitted A bar to 110
