![]() | Home > In Car Electronics > Parrot Asteroid Fitting |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
Hard to say but on what you mention it should be simple. If you intend to use an iPod or other device you may need a cable for that but you might have one with it. Other members have or have had them on here, they'd be in a better position to comment.
![]() ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Yes it fits. I had to just file the dash a little to get its metal holder in place was a little tight.
I think it looks cool as well, fit a sub and the sound is pretty good. Fits to plugs without need of an adapter. With the latest update it's great. Just make sure you follow instructions when updating. There's more to it than just pressing update with dongle plugged in. You also have to delete and then reconnect it to your iphone. |
Also unlike your units you get all the leads you need. Connect your phone with the Bluetooth which works really well. You can stream music which is great. Also set your phone as hotspot and you get google maps on the screen.
heartworm Member Since: 23 Oct 2013 Location: East Kilbride Posts: 25 ![]() ![]() ![]() |
Brilliant thanks guys, It's mainly the ipod function & handsfree I'm looking for, if it manages to do anything else it's a bonus. like the idea of having the screen showing the album artwork on it.
I use a work phone, so it's the work data it will be using, might not want to use it too much! |
It should do that just fine, if I was you make sure your iPod is fully updated before you update the Parrot too. Saves any possible niggles.
Yeah I don't bother with the maps. But the music and the hands free I use everyday. They have done a lot of updates so make sure you have the latest one.
If you get a call incoming it says their name and you just say accept or reject it works really well. |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
I fitted myself, dead easy.
Standard ISO connectors come with and comes with DIN cage which I too found to be a squeeze, but 2/3 mins of filing down did the trick ![]() Tricky bit/bit you have to decide about it's where to route the iPod/3.5mm/USB cables out to, I brought them out into the passenger side 'cubby' area, as well as running an iphone 5 cable to the dash top near the drivers side tweeter. A straightened out coat hanger is your friend for these bits. Or you can just run them out at the bottom of the centre console. See pics: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Are you left handed?
Sorry - dunno what's going on with the upside down photos! It does it if I go on my PC or my phone, doesn't seem to matter which. Hopefully you get the idea though.
It's very simple. And I love it, lots of USB Inputs, great (market best IMO) BT hands free and streaming, Internet (I don't use it but could be handy I guess) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Excellent thank you, did you need a special tool to remove the standard headunit? |
Yes now I think of it, was a
![]() Halfords or equivalent will sell the little tools you need. (I actually just asked to 'borrow' it because I was buying some other things too and they did it for me, but it should be easy enough) Think they were ford type keys if I remember Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
They remove basically like this, think it's the same keys too Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Yeah they are ford keys, the local ford dealer whipped mine out for me.
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Does the Asteroid have the facility to take a video feed (from a reversing camera..?) and display that on the screen..?
I'm looking for a single DIN unit that can do this. cheers simon |
