Home > In Car Electronics > Parrot Asteroid Fitting
Page 2 of 2 <12
Cheshire110
Nope I don't think so sorry.
Their DoubleDin unit (asteroid smart) or add-on unit (asteroid tablet) will though but I'm not sure I've seen a single din with that Cheers, David
Post #277503 28th Oct 2013 2:26pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Thanks...shame..;-(
cheers
simon
Post #277504 28th Oct 2013 2:30pm
heartworm
Scotland 2008 Defender 110 Puma 2.4 XS CSW Santorini Black
couplands wrote:
Does the Asteroid have the facility to take a video feed (from a reversing camera..?) and display that on the screen..?
I'm looking for a single DIN unit that can do this.
cheers
simon
Not as standard i'm afraid, someone made an android root kit that would have allowed this, but never officially available.
Post #277509 28th Oct 2013 2:43pm
Cheshire110
Any link/video/source? Sounds interesting! Cheers, David
Post #277513 28th Oct 2013 2:51pm
heartworm
http://www.youtube.com/watch?v=xmpb-Cgiv90
At the time there was a root, but it was V1.5 not V2.1, would be good if it worked though,
There us a thread on the net somewhere about it, but I Cant find it on a work PC I'm afraid,
Post #277520 28th Oct 2013 3:20pm
Cheshire110
looks ok, but i think you're better off getting a HU with designated rear cam feature if thats what you need.
that way it doesn't need to be USB and it should bring up the camera when in reverse automatically Cheers, David
Post #277543 28th Oct 2013 5:40pm
You'd want an AV in for video sources that are external, not cheap though. Kenwood rear cams vary between 120 - 160 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #277544 28th Oct 2013 5:48pm
heartworm
last question, doing this tomorrow afternoon, is it easy to run the microphone cable in/where did people put it, any holes need drilled?
Post #278294 31st Oct 2013 4:23pm
I put mine above the trim of the A pillar drivers side, it's common and LR fit to go on top of the steering column cowl too. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #278296 31st Oct 2013 4:26pm
Cheshire110
Dead easy for me...
I used a length of straightened out coat hanger to pull the mic end of the cable from the centre dash console out of the drivers end of the dash through the small vent which clears the window. Once I had control of it here I pushed it back in the vent and then up by the windscreen so it's at the base of the a pillar. Then I ran it up behind the a pillar (undo 2 screws, plastic comes off) and hung it out the top, and used the supplied sticky pad to stick it there.
Looks neat & no visible cables Smile Cheers, David
Post #278297 31st Oct 2013 4:29pm
steeplejack
Wales 2013 Defender 110 Puma 2.2 USW Santorini Black
Has anyone done this on a 2.2? Would I need some extra cabling to fit it as I believe the 2.2 radio wiring is not as "standard" as the 2.4?
Post #280458 7th Nov 2013 10:56pm
Cheshire110
Go to halfords or equivalent, they will have a look an sort you the right connector. Will be less than 10 and just a dead easy adaptor, no wiring needed. They will also give you the keys to remove the radio if you don't have them.
Then it's all the same as above Cheers, David
Post #280464 7th Nov 2013 11:14pm
steeplejack
Many thanks David. I'll take a trip to Halfords at the weekend.
Post #280467 7th Nov 2013 11:20pm
Cheshire110
Yeah from experience, at my local halfords anyway, there are some pretty good people. Just have to make sure they don't blindly follow their computer because defenders have been know to have the wrong parts fitted for the chassis number / model year.
I think some 2.2s had a standard ISO and some need a connector, but the halfords person will be able to tell you in a matter of seconds and they should have the keys as I said, probably worth buying a pair (think they're Ford derived?) Cheers, David
Post #280474 7th Nov 2013 11:34pm
Page 2 of 2 <12
