Home > Maintenance & Modifications > Washer squirter nozzle
Cheshire110
two bits to this question...
1) i half tried to remove my washer nozzle because i suspected it was blocked (actually i was out of fluid, doh!) and twisted it 2/3 rotations anticlockwise, and now its just all limp as hangs down. but i can't seem to get it off or tighten it up, it just spins round. so how would i remove or tighten it? (its a 2010 110 utility - heard they changed design sometime maybe?)
2) is it possible to replace it with a 2-fan jet washer nozzle? they're much better than the "just wets one teeny bit of the screen" ones that come as standard! IFAIK fan jets are mostly single fan jets and there would be two or more fitted to a car, but obviously i would need a double one. Cheers, David
Post #277067 26th Oct 2013 11:50pm
VeeTee
Netherlands
Re: 2: there was a writeup about this: http://www.defender2.net/forum/topic19806.html Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #277081 27th Oct 2013 7:22am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Great write up, also I wondered if there are any heated jets worth fitting..?
Simon
Post #277082 27th Oct 2013 7:32am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Simon, the general feeling is that properly mixed, good quality screen wash negates the need for heated jets. A Hot Shot devise might be worth fitting if you are spending some time in very cole conditions.... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #277084 27th Oct 2013 7:43am
VeeTee
Netherlands
I have the Webasto HotShot, bought second hand last year, but haven't had the time to fit it yet...
Must fit it before temperature drops Shocked Cheers, Vincent
MySite
Post #277086 27th Oct 2013 7:48am
jimbob7
As above,neat quality screenwash is good enough for the uk.
Post #277092 27th Oct 2013 8:35am
couplands
I often find a good screen wash prevents the washer bottle freezing, but the additional chill factor at the nozzle means it freezes sooner. Heated nozzles I have on the other cars helps in this regards.
Its not a major issue..Wink
cheers
simon
Post #277098 27th Oct 2013 9:10am
In arctic conditions you don't need screen wash you just get an icey dust on the windscreen, but in -5/+5 conditions a good screen wash mix works well, I've often thought about fitting BMW heated jets onto the bonnet of my defender, they are temperature controlled and only come on when it's cold. There's a good installation thread on babybmw forum.
A hotshot is a good idea but you could buy a lot of bottles of -65c screen wash for the price of a new hotshot, if you can get a 2nd hand one ... happy days !
Post #277111 27th Oct 2013 10:02am
Cheshire110
Thanks, I've seen that before and it is an option, using 2 single fan jets, but I was mostly wondering if there is a 'twin fan jet' available? Cheers, David
Post #277122 27th Oct 2013 10:54am
GUM97
1) IIRC there's a retaining nut on the back of the nozzle, on the other side of the bulkhead. This keeps it tight (obviously), but is a bit of a Censored to get to.
2) What do you mean by "twin fan jet"? A jet that has 2 holes in, providing 2 squirts of fluid? Aren't they standard? An engine to TDi for!
Post #277202 27th Oct 2013 3:52pm
Cheshire110
ughh... crawling around in the dash it is then! Sad
and i mean the fan/mist type spray pattern that some Audis/BMWs/Volvos etc have - rather than a single 'water pistol' jet Cheers, David
Post #277204 27th Oct 2013 3:56pm
GUM97
Ah I see what you mean now...
Something like this...
Insignia Washer Jets  An engine to TDi for!
Post #277207 27th Oct 2013 4:03pm
Cheshire110
Yeah that's the one!
I've just never seen a 'double' one... Cheers, David
Post #277215 27th Oct 2013 4:30pm
VeeTee
Netherlands
A bonus, even in the summer, of the HotShot is that the hot washer fluid is very effective in cleaning the windscreen from insects, tree resin and other debris... Cheers, Vincent
MySite
Post #277341 27th Oct 2013 9:11pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I have the heat shot and great devise but not in the way it's advertised. It works best in the summer when the hot water cleans the dead flys better. It will clear frost eventually on the car but not on the landy as the jets aren't powerful enough.
Worth having for £180 just!
Post #277352 27th Oct 2013 9:27pm
