![]() | Home > Maintenance & Modifications > Washer squirter nozzle |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
two bits to this question...
1) i half tried to remove my washer nozzle because i suspected it was blocked (actually i was out of fluid, doh!) and twisted it 2/3 rotations anticlockwise, and now its just all limp as hangs down. but i can't seem to get it off or tighten it up, it just spins round. so how would i remove or tighten it? (its a 2010 110 utility - heard they changed design sometime maybe?) 2) is it possible to replace it with a 2-fan jet washer nozzle? they're much better than the "just wets one teeny bit of the screen" ones that come as standard! IFAIK fan jets are mostly single fan jets and there would be two or more fitted to a car, but obviously i would need a double one. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Re: 2: there was a writeup about this: http://www.defender2.net/forum/topic19806.html Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Great write up, also I wondered if there are any heated jets worth fitting..?
Cheers Simon |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Simon, the general feeling is that properly mixed, good quality screen wash negates the need for heated jets. A Hot Shot devise might be worth fitting if you are spending some time in very cole conditions.... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
I have the Webasto HotShot, bought second hand last year, but haven't had the time to fit it yet...
Must fit it before temperature drops ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
As above,neat quality screenwash is good enough for the uk.
In arctic conditions you don't need screen wash you just get an icey dust on the windscreen, but in -5/+5 conditions a good screen wash mix works well, I've often thought about fitting BMW heated jets onto the bonnet of my defender, they are temperature controlled and only come on when it's cold. There's a good installation thread on babybmw forum.
A hotshot is a good idea but you could buy a lot of bottles of -65c screen wash for the price of a new hotshot, if you can get a 2nd hand one ... happy days ! |
Thanks, I've seen that before and it is an option, using 2 single fan jets, but I was mostly wondering if there is a 'twin fan jet' available? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
1) IIRC there's a retaining nut on the back of the nozzle, on the other side of the bulkhead. This keeps it tight (obviously), but is a bit of a
![]() 2) What do you mean by "twin fan jet"? A jet that has 2 holes in, providing 2 squirts of fluid? Aren't they standard? An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
ughh... crawling around in the dash it is then!
![]() and i mean the fan/mist type spray pattern that some Audis/BMWs/Volvos etc have - rather than a single 'water pistol' jet Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Ah I see what you mean now...
Something like this... Insignia Washer Jets An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Yeah that's the one!
I've just never seen a 'double' one... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
A bonus, even in the summer, of the HotShot is that the hot washer fluid is very effective in cleaning the windscreen from insects, tree resin and other debris... Cheers, Vincent
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I have the heat shot and great devise but not in the way it's advertised. It works best in the summer when the hot water cleans the dead flys better. It will clear frost eventually on the car but not on the landy as the jets aren't powerful enough.
Worth having for £180 just! |
