![]() | Home > Td5 > Best oil for an R380 |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Redline MTL
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic manual transmission fluid
I put this in, bought from opie oils. I don't normally believe in witches potions but this genuinely transformed my gearbox. The crunch between 1st and 2nd when cold disappeared and changes in General became so much smoother |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
Esso DEXRON lll MTF94
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
If it'a an Ashcroft supplied box i'd call/email Ashcroft and ask them! BM52
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5939 ![]() ![]() |
Diff lock oil
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I have used Difflock Evo oil and it was good but expensive! I have also used Millers XSS 10w40 oil which is MTF94 rated and that seemed to be good (and a lot cheaper than evo) as you can buy it in 5 litre bottles for about £22.
Fuchs TITAN SINTOFLUID SAE 75W-80 is exactly the same as difflock oil but a lot less money
MTF94 as adviced by LR Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
The first time you put oil in it, just buy some official Land Rover oil for it, make a note of exactly what type it is, then buy from a more reasonably priced supplier afterwards.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
http://www.defender2.net/forum/post85528.html#85528
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Thanks guys,
I'll give the Difflock/Fuchs oil a go then. Thanks Martin, i did do a search and found that one and other posts, just wanted to see if there was anything else new on the market. Regards, Mark |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 433 ![]() ![]() ![]() |
i dont know if you have ever used it but i use lucus oil stabaliser and additive in every oil tank on my whole landy. The engine runs smoother, tranny all runs quiter and smoother and on my 110 v8 i runn it real strong in the main gearbox as it helps the syncro and keeps it quie. Just an advise, i normally just use the recomended oil but make sure that i use the best quality oil i can get with in a reasonable price.
Carlosbeldia Member Since: 13 Oct 2013 Location: Cartagena Posts: 43 ![]() ![]() ![]() |
Can I mix Dexron with MTF94? it seems to be ok in the bulletin...
Well i plumbed for the Difflock Evo 1 oil and i must say i am astonished! Gone are the crunchy gears and it now virtually falls out of 5th and reverse on its own! Definitely a huge
![]() Thanks for your advice guys. Regards, Mark |
