Home > Td5 > Best oil for an R380
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Hi guys,
I know its been covered before but what are people experiences with gearbox oils in an R380? I have put the Ashcroft R380 conversion kit on my 200Tdi.
The problem is, it is really difficult to get into 2nd, 3rd going up the gears and difficult to get out of 5th and reverse. I am thinking of changing my gearbox oil to the Difflock Evo 1. Any experiences with this 20,000 miles down the line?
I have also just heard that GL5 oils eat bronze phosphor parts and therefore are no good for gearboxes now. Anyone also heard this?
Thanks in advance for your thoughts.
Regards,
Mark
Post #276426 24th Oct 2013 8:06pm
ibexman
Redline MTL Thumbs Up
Post #276428 24th Oct 2013 8:09pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic manual transmission fluid
I put this in, bought from opie oils. I don't normally believe in witches potions but this genuinely transformed my gearbox. The crunch between 1st and 2nd when cold disappeared and changes in General became so much smoother
Post #276441 24th Oct 2013 8:33pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Esso DEXRON lll MTF94 Thumbs Up
Post #276448 24th Oct 2013 8:51pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
If it'a an Ashcroft supplied box i'd call/email Ashcroft and ask them! BM52
Post #276451 24th Oct 2013 8:53pm
landy andy
Diff lock oil Thumbs Up Thumbs Up
Post #276452 24th Oct 2013 8:53pm
Alex1976
I have used Difflock Evo oil and it was good but expensive! I have also used Millers XSS 10w40 oil which is MTF94 rated and that seemed to be good (and a lot cheaper than evo) as you can buy it in 5 litre bottles for about £22.
Post #276458 24th Oct 2013 8:59pm
Jimb1978
Fuchs TITAN SINTOFLUID SAE 75W-80 is exactly the same as difflock oil but a lot less money
Post #276459 24th Oct 2013 9:00pm
VeeTee
Netherlands
MTF94 as adviced by LR
Quote:
Defender Date: 25.11.98
AFFECTED RANGE: All R380 manual gearbox derivatives - refer to text for specific change points
PROBLEM: GEARBOX OIL - CHANGE TO SPECIFICATION
CAUSE: At the following VINs, the original oil fill specification for the R380 gearbox was changed to Texaco MTF94 high performance oil:
Range Rover - WA 384300
Discovery - WA 752315
Defender - WA 131138
New Discovery - All vehicles
The Freelander PG1 gearbox has used the new oil since introduction of the model.
ACTION:
MTF94 will be recognised by its orange/honey colour as opposed to the red Dexron II oil previously used, and is now available from Land Rover Parts.
It is now the only oil which should be used for topping up and complete fill on R380/PG1 gearbox applications.
The new oil is compatible with the old and to enable earlier vehicles to benefit from its introduction, should be used retrospectively on vehicles prior to the above VINs for all top up and refill requirements.
Refer to PARTS INFORMATIONoverleaf for details.
Until further notice, current Service Schedule gearbox oil change periods are retained and must be adhered to.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #276469 24th Oct 2013 9:34pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
The first time you put oil in it, just buy some official Land Rover oil for it, make a note of exactly what type it is, then buy from a more reasonably priced supplier afterwards. Wink 1998 110 300Tdi White Hard Top
Post #276491 24th Oct 2013 11:37pm
Martin
Site Admin
http://www.defender2.net/forum/post85528.html#85528  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #276493 24th Oct 2013 11:49pm
pope10001
Thanks guys,
I'll give the Difflock/Fuchs oil a go then. Thanks Martin, i did do a search and found that one and other posts, just wanted to see if there was anything else new on the market.
Regards,
Mark
Post #276525 25th Oct 2013 8:34am
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
i dont know if you have ever used it but i use lucus oil stabaliser and additive in every oil tank on my whole landy. The engine runs smoother, tranny all runs quiter and smoother and on my 110 v8 i runn it real strong in the main gearbox as it helps the syncro and keeps it quie. Just an advise, i normally just use the recomended oil but make sure that i use the best quality oil i can get with in a reasonable price.
Post #276588 25th Oct 2013 1:58pm
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
Can I mix Dexron with MTF94? it seems to be ok in the bulletin...
Post #276798 26th Oct 2013 4:15am
pope10001
Well i plumbed for the Difflock Evo 1 oil and i must say i am astonished! Gone are the crunchy gears and it now virtually falls out of 5th and reverse on its own! Definitely a huge Thumbs Up from me!
Thanks for your advice guys.
Regards,
Mark
Post #277043 26th Oct 2013 10:05pm
