![]() | Home > Wheels & Tyres > New Tyres Rubbing |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
It would be likely that your steering lock stops need winding out, did you have smaller tyres previously ? 2005 Td5 90 XS
Steve |
| CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135
Thanks for the feedback - yes, I had 205 80 16's on it.
The place that put them on should have known this |
Thinking about it, it only seems to rub one way, so that would presumably confirm your thinking
Unfortunately a lot of places don,t understand our Defenders ! 2005 Td5 90 XS
Steve |
| Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439
Exactly the same thing happened to me going to and from the same sizes.
Less than a minute to fix. Very simple, small adjustment. Bit specialist a thing for a tyre place to pick up I would have thought. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Were the same alloy wheels on the car before you fitted this set of tyres ? If they are a new to the car set of wheels they could have a slightly different offset to what you used to have fitted ?
Pete. Last edited by bell-auto-services on 23rd Oct 2013 7:56pm. Edited 1 time in total |
Yep, same alloys, just new tyres.
First port of call tomorrow is where they were fitted to point out the problem, and hopefully wait for the 2 minute fix |
Ahh. Then as already mentioned it just does sound like the steering stops need a tweak for the larger tyres. They were most probabally set up on the smaller tyres for maximum lock hence your problem now.
Pete. |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065
So your steering lock will be worse once adjusted
Mine stopped rubbing after a tiny adjustment. No effect on turning - hopefully yours too!
I'm always astonished at the price of spacers, given what they are... 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1657
If they do adjust your lock stops get them to wind them all the way out and copaslip them before refitting.they can be fff ing tight if they have never been moved
| Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171
To be honest, I find it very peculiar you had 205/80/16's to begin with since this size is much too small for a Defender (would be quite interesting to see a photo!)
Blaming them for tyre rub when what they have fitted are standard size tyres on standard size rims is a bit hasty. |
They are (or at least were) standard equipment on my hardtop. 2003 Td5 110 Hardtop
