![]() | Home > Puma (Tdci) > Puma Engine Mileage |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Hi!
29000 km 2009 (purchased in dec 0 ![]() model 90 S No engine issues at all, running beautiful and drinking a brasilian diesel, high sulfur, 5% biodiesel, full of water and mud!!! (and other things that I can't identify). The best of it is the generous torque!!!! Just loving all of it!! |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 ![]() ![]() ![]() |
Hi All
28k miles 2008MY Usage: Motorways and A&B roads only Engine: No problems (yet)!! Conclusion: Loving it ![]() |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
How do lads.
2008 110 with 7000 miles. 95% on 5% 0ff road No engine problems yet......... but I have noticed a change in engine note at tickover sometimes, it gets louder and sounds a bit rough when I first blip the throttle?. Richard 1963 Series 2A truck cab 2008 110 SW |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 ![]() ![]() |
Hi all,
2007 MY 110 SW roughly 65000 Kms Usage - maily A roads and smaller (70 kms daily drive to work) Long (holiday) motorway drives. a few thousand Kms (5000 ?) with a heavy (3 Ton) trailer. Lives in the east of France. Motor not too happy when temperature has dropped below -10 overnight, positively unhappy after -20. Has destroyed a common rail and fuel pressure relief valve (replaced under guarantee), also has an intermittent loss of power that might be the EGR, but Landrover are not sure, although you don't want to know about that, right? as its the EGR. Jon |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
2008 XS SW 90. 13100 country miles.
Bosvark Kzn Member Since: 04 Sep 2014 Location: Port Shepstone, Kzn, South Africa Posts: 7 ![]() ![]() |
2011 Puma 2.4
195000 km, still going strong. |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
13k miles
64 plate Usage: Normal roads Engine problems.... it's a diesel ![]() |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
89k miles
12 Plate Heavy towing / fast roads / general farm duties New engine at 75k - oil pump failure / warranty engine before I bought it. Far far better than a FullFat ![]() ![]() |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
89K miles
2008 USW 99% road use inc towing No major issus apart from holed intercooler hose & good serivicing by myself ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
71k miles.
2010. 110 csw xs. No engine issues but ancillaries - new turbo and ecu. Engine running 450Nm re-cal with egr blanked and running v sweet. ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17978 ![]() ![]() ![]() |
Seeing that this thread has miraculously come alive again after a 6 year sleep!
190,000 miles, 2007 DC 110, engine problems - 1 VCV, 1 chafed harness, 1 bolt on exhaust manifold persistently working loose. That's all I can remember anyway. EDit - remembered that I have also had to replace the water-pump, due to a weeping seal on the shaft. Last edited by blackwolf on 25th May 2016 10:09am. Edited 1 time in total |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
33K miles, MY2007 2.4 TDCI.
Serviced only once prior to my buying it last December but it sounds good and pulls like a train. Only time will tell... |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Most that have posted seem to be early 2.4's. Where are you high mileage 2.2 boys?
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
i could be in for lowest mileage 2.2?
- Mileage: 2 (if you discount the miles it had from the dealers) - Year make: 65, 90 - Body type: pickup -The main use of the vehicle (city,country,farm,comp) etc: sit in a bubble till we decide what to do with it ![]() picked up on a trailer to keep low miles ![]() ![]() Click image to enlarge |
