Could do with one of them for my afternoon coffee - very envious
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
It's definitely a defender all the panels are odd sizes and fit badly
Washed, clay barred and waxed her twice so she should be ok in the salty roads of winter! I'm now knackered and need a bath
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Haven't got Betty while Chris at CSK is working his dirty magic
![]() ![]() ![]() Click image to enlarge Bit fiddly feeding two wires into crimp slot for one but got there in the end ... only problem is I didn't count enough ends to make so waiting for postie to deliver two more connectors before finishing ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
Checked oil & water & mounted the orange beacon light bar ready for the weekends rally. For those interested, its the 58th Cambrian Rally in North Wales. 1999 Defender TD5 110
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there
Old style Land Rover plate installed in the rear instead the normal oval logo that was moved to the front. (10 minutes work). Looks very good ![]() Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Good news the badges have arrived! 1999 Defender TD5 110
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Fitted my new Def2 sticker, last one was KIA by K90....
![]() Puma Defender 90 |
Thanks excossack ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
No probs. 1999 Defender TD5 110
Guess where I've been today ... and it's not back to Gary !
![]() Click image to enlarge Great job on the dinitrol and dynamatting - thanks Chris ![]() |
Was he so good you went twice?
![]() ![]() Sorry couldn't resist! An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Sorted out the loose rivnut which wasn't holding my sub to the rear bulkhead in the dc very well. I didn't realise how much the amplified vibrations were annoying me until they stopped!
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
A few weeks ago I noticed my radio reception was getting weaker and weaker, the connection on the back of the radio was fine so checked the bottom of the Antenna.
I have seen bolts emerge from the North Sea in better condition- replacement was needed. Popped down to halfruads and bought a replacement, carefully cutting the old wire on the engine side of the bulkhead and then tapeing the new wire and connector to the old one. Sat in the cab and then slowly and gently pulled the old wire through the bulkhead bringing with it the new wire. Needless to say, the tape snagged and the connector got stuck and a neatly cut cable emerged into the cab with no new wire attached. ![]() ![]() ![]() Fast forward to today, having listened to all my cd's and got stuck in all the traffic jams I decided I really needed my radio so out comes the screwdriver and the dash. I found 2 dead wasps, a penny, a compass, a pencil, a bullet connector and lots of dust and the other end of the new wire! Hooray! After a bit of a fight managed to get it all back in correctly and sat listening to Radio 2 happily for the first time in weeks. Quick oil and coolant top up and a quick drive around the block to make sure I put all the squeaks and rattles back in the right places ![]() ![]() |
