Home > Off Topic > Connecting I pad to TV via composite av cable
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Bit lost really, I want to connect I pad to TV so I can watch BBC I player etc and also view pictures.
I have the av cable and have managed to get pictures from I pad onto telly, but quality is not very good, do I need to change settings somewhere?
Then, can't get I player which is playing on I pad to play on TV, do I need some more kit?
Any guidance for a I pad novice would be appreciated,
Pete
Post #273752 14th Oct 2013 5:45pm
mk1collector
I think they have a product called Apple TV for this but I've never used it myself
Post #273756 14th Oct 2013 6:02pm
GUM97
Here's the link:
Apple TV An engine to TDi for!
Post #273781 14th Oct 2013 6:54pm
VeeTee
Netherlands
The Apple TV is a great bit of kit! It lets you stream wireless everything from your iDevice (iPhone - iPad - iMac) on your TV. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #273794 14th Oct 2013 7:10pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
As above, Apple TV allows you to stream video from any iOS device over WiFi as well as giving you access to online TV services (which you can also control from your iOS device.
If you have a spare Mac or PC that you can connect to the TV you can also get some software that will allow you to stream from your iOS device...
http://www.airserver.com/
I'm using the above on an old MacMini that's hooked up to the music system and TV in the living room, primarily used for playing music rather than video. Not as good as Apple TV for video and if you have an oldish TV you might struggle to connect the PC/Mac to it but it's also a lot cheaper (free to try it). http://www.yorkshireoffroadclub.net/
Post #273814 14th Oct 2013 7:30pm
peterl
Thanks for this, so to sum up, if I get Apple TV, can I watch BBC I player, itv player etc from my I pad onto the main tv?
Also, when I plug the I pad into the telly to look at my photos, the larger picture is of very poor quality, do I need to change settings somewhere?
Post #273824 14th Oct 2013 7:47pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
1st of all, how old is your TV? Does it have a HDMI input?
If it does what version iPad do you have?
You can get an IPad to HDMI lead combined with a charger lead that allows you to plug the iPad into the HDMI socket on the TV. Select the correct HDMI input on the TV and your iPad screen will be duplicated on the TV in high definition.
http://www.ebay.co.uk/itm/1080P-Dock-Conne...19e0089dab LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #273856 14th Oct 2013 8:50pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
I've got the Hdmi cable - works well.
Post #273867 14th Oct 2013 9:06pm
peterl
Ok, TV has hdmi and the I pad is new, (don't know version).
When I plug the composite AV cable in, I can play a photo slide show, but the quality is very poor compared to photos direct to TV via a memory card or sd card.
Would the hdmi lead produce better images or am I doing something wrong.
Post #275579 21st Oct 2013 4:19pm
WelshGas
I have only used a HDMI lead, but everything shown on the iPad is shown in HD quality on my tv. Thumbs Up LANDYWATCH
Post #275655 21st Oct 2013 7:48pm
