| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Fitted new (TD5) injector harness.
Goes like a rocket now........ ![]() |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Ran it thru the car wash, including hot wax. Towel dried it, treated all 5 tires with Michelin tire shine, WD-40 inside both trailer sockets, inside antenna, and on the door hinges. Treated all exterior plastic bits with a matt plastic cleaner, including the A-bar, front bumper end caps, engine and fan covers, door handles... Checked oil level and tire pressure, and last but not least, removed my emission control sticker from the rear side window, even if it was still good til April 2014...
Before.... Click image to enlarge and After.... Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82
I have the same problem - I think I'm going to get a Garmin device to replace the tomtom one |
| Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444
Hi BM52 and Generaldej,
Its the main reason I swapped to Garmin, they also have free lifetime traffic and map offers at the moment. Just can't find a Garmin hardwired kit, or a separate traffic cable. Also even with the updates, TomTom kept loosing its traffic signal??? _______________________________ Puma Defender 90 |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Replaced the viscous fan coupling.
Gone from being a slight breeze to a howling gale so success! The old one was well dead... Click image to enlarge |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Never mind the viscous coupling SD tell me more about those barrels behind ! 2005 Td5 90 XS
Steve |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
got muddy
Refitted the amp and sub as the dogs rarely get into the 90 now. Had it sound checked by an expert
Puma Defender 90 |
@ lousparts
Not barrels unfortunately, it’s a cylinder block for a vertical steam engine. Currently undergoing a repaint and restoration. Defenders are powerful, but nothing against twin 6"x8" piston valves Talking about barrels though, have always wanted to make a cannon. |
Ah i was thinking two stroke motor cycles when i saw them,wishful thinking i guess. 2005 Td5 90 XS
Steve |
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Fitted Td5 dash warning lamps and switches to centre dash. Just need the plug from a TD5 rear loom so I can solder to my loom and then connect to Td5 rear door. The orange light on rear heated screen switch is on with dash illumination. Well if thats all thats wrong after a lot of snipping of wires, it cant be bad !!
| william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259
Installed an underbid net light today. As I got a bargain on some strip lights on eBay. Parts used was some thin wire, a discovery 2 bonnet alarm switch and the light.
Click image to enlarge And at night.. Click image to enlarge Click image to enlarge William |
| carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707
Bought some lowered 110 springs from Alive and some Bilstien B6 shock .. Just need to fit them now
| AlexPuma42 Member Since: 13 Jun 2013 Location: Manchester Posts: 43
went over to see my mate in the west country ended up dragging his series from under a tree thats been growing around it for the past 4 years - I keep mithering him to sell it me but no look yet!
Click image to enlarge 110 Hard Top - Izmir Blue |
