| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Hardwired my el-cheapo heated seats into some switches on the dash console and now opened a whole can of worms on other switches I've previously put in. I knew I shouldn't have tried to rush it, damned school runs! Still a job for Saturday along with replacing the abs shuttle valve solonoids that arrived today. Hopefully that will sort out the re-occouring illumination.
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
And did a nice BDR repair on the coolant pipe that decided to split open in the middle of nowhere. Still, managed to do 114 miles beforehand. Had a gentle slow drive back home with the coolant filler cap loosely fitted so the system didn't pressurise and blow my bodge repair apart. Think I'll be getting a new pipe tomorrow and possibly pulling the head off to see why it keeps pressurising the system ![]() ![]() ![]() |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Nothing.
My wife has nicked it on the pretence she needs it for work Last time she borrowed a car I didn't get it back for about 3 years |
| Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82
Tried to fit the defender into the garage today so I could check the oil level. Everywhere else on our drive slopes in one direction or the other. Had to empty the garage as we don't use it for vehicles.
Where it ended up was on flat ground so I was able to measure the oil level anyway - after all that I didn't have to put any in ![]() |
Did you manage to get the bonnet stay in position, that must have been close
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Steve, seems easier said than done. Any ideas? You will remember a thread about exactly this that I started long time ago and which received several followers, including you, and also some encouragement from potential suppliers/site sponsors,.... but then it went quiet. So seems not an evident thing to do. Guess the SVX style front is still a too limited potential market for companies like Speaker to engineer an easy fitting solution, even if they already do have 90mm high beam LED lamps in their assortment. Here is the link to the mentioned thread. Guess more people would be interested, so maybe we have to revive it.... http://www.defender2.net/forum/topic16121....lights+led You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I am assured its work in progress
Steve, just responded to your PM
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
Finished bedding her in
Click image to enlarge |
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808
Brilliant...mine is just freeing up after a little under half that mileage!
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Took the rear sets out
Mine just went over 160k yesterday |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Picked up the bits to make my own side window demisters, just need dry weather now
| Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444
Took out the twin USB socket, put back the land rover connector as the new Garmin Satnav wont allow the traffic to work with the hard wired TomTom one I had previously fitted. The connector is the same but it kept warning of incorrect cable, read the instructions and it seems it will only work with the cable in the box which only fits the original outlet.
Puma Defender 90 |
