![]() | Home > In Car Electronics > Double Cab Audio From Scratch? |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
Papa, its is reasonably easy, just measure twice cut once, and think about what your doing. You are more than welcome to make a trip here, and I'm sure Steve would also help you with fitting. To me the fronts are the important/expensive ones. They will provide the highs and mids that will give clarity
![]() ![]() Steve - ^^^^ thats called charecter ![]() |
Papa Lazarou Member Since: 11 Sep 2013 Location: West Midlands Posts: 40 ![]() ![]() |
Thanks for your kind offer Jim, I appreciate it. I'll give it a go and if I get stuck / start wrecking stuff I may just take you up on it
![]() ![]() I've got a dremel buried in the depths of the shed somewhere so I'll definitely be digging that out then. Cheers ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Good luck.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Right then. After all the great advice and encouragement on here, I went for it. Got myself some Focal 130VRS components to go with my Kenwood KDC-BT52U head unit. I also needed one of those facia bezel surround things as the DC has never had a stereo fitted before and the dash looked like this (I have no idea why picture is sideways on here!):
![]() Click image to enlarge For anybody who's interested, this is how it went. First step was marking out the lower dash for the holes for the woofers. At first I struggled a bit with the positioning of the passenger side woofer. The mounting plate wouldn't quite sit flat against the wiper motor cover because of the curve of the panel at the edge. A quick call to Jim got it sorted though ![]() ![]() I marked out the holes using the mounting ring as a template. It was a bit difficult to see the lines though so I went over them with tippex ![]() ![]() Click image to enlarge So far so good............ |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
and...
They all lived happily ever after
I think you need you add more photos.
Got some photos on my phone and some on a camera but seem to have a problem with the camera at the moment
![]() ![]() I fitted the woofers and ran wiring to where the cross overs were going to be mounted: ![]() Click image to enlarge Next step was deciding where to put the shiny new x overs ![]() Click image to enlarge Passenger side was easy as there's plenty of room behind the wiper motor cover. Mounted mine in the same place as Jim - see his photo earlier in this thread. Driver's side not so straightforward though. I couldn't make room behind the instrument binnacle or anywhere else over that side so I ended up running all the wires back into the centre console. I decided I would be fitting the RHS x over in there, underneath where the HU goes (can't post that pic at the moment). Next up was the cutting of holes in the top of the dash for the tweeters. I wasn't looking forward to this bit..... |
and ...
And....
Don't you start Steve
![]() ![]() ![]() More sideways pics to follow shortly ........ |
