Home > In Car Electronics > Double Cab Audio From Scratch?
Page 3 of 4 <1234>
Jim - You just need to change that rusty screw now. Whistle
Thumbs Up Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #269123 24th Sep 2013 7:04pm
barbel jim
Papa, its is reasonably easy, just measure twice cut once, and think about what your doing. You are more than welcome to make a trip here, and I'm sure Steve would also help you with fitting. To me the fronts are the important/expensive ones. They will provide the highs and mids that will give clarity Thumbs Up Having a dremmel to hand also makes fettering easier Whistle
Steve - ^^^^ thats called charecter Ner Ner
Post #269354 25th Sep 2013 2:57pm
Papa Lazarou
Thanks for your kind offer Jim, I appreciate it. I'll give it a go and if I get stuck / start wrecking stuff I may just take you up on it Mr. Green And yes, Steve's been a lot of help already too Thumbs Up
I've got a dremel buried in the depths of the shed somewhere so I'll definitely be digging that out then. Cheers Thumbs Up
Post #269399 25th Sep 2013 6:24pm
Good luck. Thumbs Up ____\We|Will|Win/___
Post #269411 25th Sep 2013 7:00pm
Papa Lazarou
Right then. After all the great advice and encouragement on here, I went for it. Got myself some Focal 130VRS components to go with my Kenwood KDC-BT52U head unit. I also needed one of those facia bezel surround things as the DC has never had a stereo fitted before and the dash looked like this (I have no idea why picture is sideways on here!):
For anybody who's interested, this is how it went.
First step was marking out the lower dash for the holes for the woofers. At first I struggled a bit with the positioning of the passenger side woofer. The mounting plate wouldn't quite sit flat against the wiper motor cover because of the curve of the panel at the edge. A quick call to Jim got it sorted though Thumbs Up He suggested I gently tapped out the rear of the cover using an engineering hammer to slightly straighten out the edge of the curve and it worked a treat. Got the mounting plate sitting perfectly flat with no change to the appearance of the front of the cover. Great tip Thumbs Up
I marked out the holes using the mounting ring as a template. It was a bit difficult to see the lines though so I went over them with tippex Mr. Green That made them much clearer! Started carefully stitch drilling inside the lines and before long I had 2 neatish holes in my dash. A few minutes with a file and that part was done.
So far so good............
Post #273111 12th Oct 2013 12:29pm
Tiger
and...
Post #273113 12th Oct 2013 12:32pm
Papa Lazarou
They all lived happily ever after Laughing hang on, had to stop to do something else...more in a bit....
Post #273121 12th Oct 2013 1:14pm
I think you need you add more photos. Laughing ____\We|Will|Win/___
Post #273124 12th Oct 2013 1:46pm
Papa Lazarou
Got some photos on my phone and some on a camera but seem to have a problem with the camera at the moment Banging Head And I still can't work out why my photos are all sideways on here! Laughing
I fitted the woofers and ran wiring to where the cross overs were going to be mounted:
Next step was deciding where to put the shiny new x overs
Passenger side was easy as there's plenty of room behind the wiper motor cover. Mounted mine in the same place as Jim - see his photo earlier in this thread. Driver's side not so straightforward though. I couldn't make room behind the instrument binnacle or anywhere else over that side so I ended up running all the wires back into the centre console. I decided I would be fitting the RHS x over in there, underneath where the HU goes (can't post that pic at the moment).
Next up was the cutting of holes in the top of the dash for the tweeters. I wasn't looking forward to this bit.....
Post #273138 12th Oct 2013 2:43pm
Tiger
and ...
Post #273146 12th Oct 2013 3:38pm
And.... Rolling with laughter ____\We|Will|Win/___
Post #273147 12th Oct 2013 3:56pm
Papa Lazarou
Rolling with laughter I'm having technical problems Tiger
Post #273149 12th Oct 2013 3:58pm
Papa Lazarou
Don't you start Steve Rolling with laughter
Post #273150 12th Oct 2013 4:00pm
barbel jim
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter oh and don't mind Steve Greg, he's only got 4" up front, you have an additional 25% to him Rolling with laughter Mr. Green
Post #273152 12th Oct 2013 4:09pm
Papa Lazarou
Rolling with laughter Rolling with laughter I'm told that it makes all the difference Laughing
More sideways pics to follow shortly ........
Post #273154 12th Oct 2013 4:15pm
Page 3 of 4 <1234>
