Home > Maintenance & Modifications > Transfer box - changing to a Disco box?
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
I know this topic has covered before but I would really appreciate
some further opinion. I've been offered a 'swap' for my transfer box (TD5 110)
with one from a 2002 Disco 2. I 'm keen, but would like to know from
those who have made the change is it definitely worthwhile, do you lose much
'Tractability' and does it help get rid of the box 'whine' on the motorway (Do Discos
have a quieter gearing? ). I don't pull heavy trailers, plus have had a standard BAS tune.
Many Thanks.
Post #272972 11th Oct 2013 5:56pm
equipe59
United Kingdom 2003 Defender 90 Td5 CSW Stornoway Grey
Hi,
Yes
No
No
Hope that helps!! Thumbs Up
Seriously though, I changed mine but in the end went for an Ashcroft box as the tranny box I considered was a second-hand Disco TDi200 box, but my spanner-man (MiD Engineering) advised against it as a tweaked TD5 would have a fair chance of wrecking it - something to do with the cross-drilled input shaft, or rather lack of Sad
As I like my 90, and want to keep it for a while, I decided a 'known quantity' tranny box was a better bet Thumbs Up Glad I did as when I opened up the Disco box for a look-see, the innards were full of emulsified oil-and-silt mix, which would have been expensive... Shocked
Post #272994 11th Oct 2013 7:29pm
Re: Transfer box - changing to a Disco box?
DC101 wrote:
with one from a 2002 Disco 2. .
Bear in mind that this era of disco transfer may not have the difflock linkage on it... you may need to swap some bits over or buy the relavent parts (Ashcrofts springs to mind) to make the disco box difflock-able.
Post #272995 11th Oct 2013 7:31pm
DC101
Thanks for the advice. Thumbs Up With reference to transfer box noise, I had in my mind somewhere that I was told about a 'Q' denoted gear set, which meant the gears ran quieter than the standard Defender. Have I imagined this? Question
I would really like to lose the whine at motorway speeds.
Post #273021 11th Oct 2013 9:44pm
Retroanaconda
You shouldn't be able to hear the transfer box at motorway speeds. Certainly not over the engine, road and wind noise anyway. If there's a noticeable whine then something's amiss.
There is a Q variant yes with quieter gears, can't remember what it was fitted to though I am afraid!
Post #273024 11th Oct 2013 9:51pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
yes dfinateley worth while and with a tune makes it much more driveable bas done a really nice smooth tune on mine and can now cruise at 80 but will touch 100 if pushed
best mod I have done to mine so far 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #273027 11th Oct 2013 10:01pm
Martin
Site Admin
All Td5s have LT230Q transfer boxes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #273029 11th Oct 2013 10:08pm
DC101
The whine is noticeable on slow (55+) motorway speeds, and noisier the faster you go (not that I go that fast..!).
Not having driven anyone else's TD5 I assumed it was normal.
Post #273030 11th Oct 2013 10:11pm
Mine doesn't have the Q gears (not that I know of anyway) and it's not unduly noisy.
Although having said that, i've not driven any great distance in a puma so can't really compare.
Post #273031 11th Oct 2013 10:17pm
Gareth
Mine has a road speed related whine at anything over 45. It gets drowned out by other noise at about 65. I had the oil changed and it did quieten it down a bit. Its always done for as long as I have had the vehicle, and has got no louder. Previous owner also said it had always made the noise, So I too presumed they all did it.
I have not swapped the gears yet, but am planning to rebuild my own box. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #273074 12th Oct 2013 8:20am
jst
NOT ALL TD5s has Q gears Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #273226 12th Oct 2013 9:29pm
DC101
Thanks for the replies . The noise from mine also 'goes' at 'higher' speeds due to being lost in the general racket. My main reason for the transfer box change is quieter motorway driving, and hopefully the lower engine revs will significantly help. Out of interest, if not all TD5's had a Q box, is there anyway of telling on the box casing etc ?
Post #273299 13th Oct 2013 11:11am
