![]() | Home > Technical > Front diff clunk? |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Thats normal right? you can adjust the back lash reducing free play I once spent alot of time on a defender adjusting each diff tightning up gear selector diff and refitting output and hubs all felt very perfect
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663
A little backlash is normal and required I know
It's certainly a very harsh clunk and not within the 'normal' relms How does one adjust? |
Get a workshop manual it'll walk you through it mate. Mine needs adjusting too as mine chunks like yours just very short in time lol
Got one, been through it several times, but not found anything under "Adjustment" in terms of diff backlash!?
Literally just looked through the front diff re-build section to! |
There is a grub screw/bolt inside that moves the diff Pinion in or out. There is a measurement for the gap in the teeth. Wow its been some years since transmissions on my mechanics course lol. Perhaps ill have To make time to adjust mine sooner then o I can publish a how to
Ahh you mean the crownwheel clearance!
That could sort the problem, just not sure it 'feels' like its that easy a fix, but worth a shot non the less! Would save me a lot of money because I would no doubt somehow talk myself into some lockers if the diff was gone |
Pow! sorry used the wrong term crown wheel adjustment but its called back lash this thrwad explain. Allhttp://www.lrrforums.com/showthread.php...and-pinion
Yep, got the link working, that pirate 4x4 link is nice! Like looking at pictures does I
Hmm ... Maybe worth a go one weekend! Sorry for my confusion of terms there, not the greatest with words |
Could partly be my fault as I learned my basic skills in the army. My assumption that a workshop manual was incorrect as apparently its not a normal workshop job. The pirate link really lays it out lol I too require picture stimulation lol. certainly demonstrates how to adjust although the thread is about replacement
