![]() | Home > Technical > Cleaning a DCPU Plastic/PVC Canopy/Tilt |
| Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725
I got a auto gleam kit from my moto factors. It had a soft top cleaner and a seperate waterproofer. Came up ok with a bit of work. I did think of trying a tent company like blacks of Greenock as they make canvas tents
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
The issue is the "new" tilts are not made of a traditional material such as canvas and so the use cleaning products do not seem applicable?
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Do you mean mohair roof or the industrial Vinyl type that adorns yer typical MOD landrover,either way try something from here,as with everything "fabric" don't use to high a concentration as it could make the fabric brittle.
Haven't used any of these but detailers recommend it. You also need to seal it after,it will help keep it cleaner. http://www.theultimatefinish.co.uk/cabriol...-care.aspx http://www.renovointernational.com/products/dryclean.php http://www.polishedbliss.co.uk/acatalog/30...cat18.html |
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861
Kitchen general spray diluted 50/50 with hot water, spray and use a non stick scouring pad, should work a treat.
| Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 831
I have used Muc-off with good results in the past, also great for cleaning your headlining.
Its used for cleaning down mountain bikes any bike shop should have it Nidge |
