Home > Technical > Cleaning a DCPU Plastic/PVC Canopy/Tilt
Mine seems to get dirty quite easily and holds the dirt in what is quite an open mesh pattern when looked at close up. I also have run lines where the water runs off the roof of the canopy and stains down the sides in a number of places.
Ordinary car shampoo does not seem to lift the dirt and I'm a little concerned about using anything stronger in case it actually attacks the plastic.
Any recommendations?
Post #269886 28th Sep 2013 9:20am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I got a auto gleam kit from my moto factors. It had a soft top cleaner and a seperate waterproofer. Came up ok with a bit of work. I did think of trying a tent company like blacks of Greenock as they make canvas tents
Post #269905 28th Sep 2013 10:56am
The issue is the "new" tilts are not made of a traditional material such as canvas and so the use cleaning products do not seem applicable?
Post #269908 28th Sep 2013 11:12am
jimbob7
Do you mean mohair roof or the industrial Vinyl type that adorns yer typical MOD landrover,either way try something from here,as with everything "fabric" don't use to high a concentration as it could make the fabric brittle.
Haven't used any of these but detailers recommend it.
You also need to seal it after,it will help keep it cleaner.
http://www.theultimatefinish.co.uk/cabriol...-care.aspx
http://www.renovointernational.com/products/dryclean.php
http://www.polishedbliss.co.uk/acatalog/30...cat18.html
Post #269989 28th Sep 2013 8:06pm
Leenorthants
D
Kitchen general spray diluted 50/50 with hot water, spray and use a non stick scouring pad, should work a treat.
Post #269990 28th Sep 2013 8:13pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I have used Muc-off with good results in the past, also great for cleaning your headlining.
Its used for cleaning down mountain bikes any bike shop should have it
Nidge
Post #270092 29th Sep 2013 11:11am
