Home > Maintenance & Modifications > Driving light wiring conundrum
Page 2 of 2 <12
kipperthedog
Will you actually want the driving lights on without headlamps? If not an ON-OFF would do. On with heads - Off - On independently makes sense for roof mounted lights which you may want to use as work lights or have on independently because the headlamps are submerged! But I probably wouldn't bother with an ON-OFF-ON for bumper or A-bar mounted lamps myself.
Post #269430 25th Sep 2013 7:51pm
I asked the same thing further up. I've got 2x KC daylighters on my 110, both 100 odd watts. They come on/off with main beam. not switched. no probs or hassle.
Post #269432 25th Sep 2013 7:57pm
Steve
here is a copy of the land rover spotlight fitting kit, all you would need to add would be an isolator switch. This gives you an idea of how they do it in the factory... good or bad Shocked
https://www.defender2.net/gallery/albums/userpics/10260/TDCi.pdf
Post #269433 25th Sep 2013 8:01pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
K9F wrote:
You could just tap off the high beam feed in the cab and supply the on contacts of your independant switch. Would cut down on wiring and still be independantly isolated by your switch from the normal main beam headlights. Of course you'd only be using two of your three sets of contacts. The extra set could be used for further lights if you wish to add more later perhaps?
If you've the switch in manual on from your diagram you would have to operate the switch manually to dip them. Bit of a faff if you've an unexpected motorist heading towards you.
Thumbs Up
Picture mate, I need pictures!
Post #269470 25th Sep 2013 10:08pm
K9F
Whistle
Switch the earth to the relay and not the live - Best working practice.... Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #269480 25th Sep 2013 10:41pm
Page 2 of 2 <12
