![]() | Home > Maintenance & Modifications > Cleaning alloys? what to use? |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Concrete cleaner from one of the big DIY chains gets baked on brake dust off.
As a normal cleaner i use Quantum alloy wheel cleaner from VW,s trade parts outlet TPS,works a treat. 2005 Td5 90 XS Steve |
WD40 works well, as does Autoglym Clean Wheels
Just remember WD40 eats Rubber
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 ![]() ![]() ![]() |
neat TFR, traffic film remover, use gloves as it drys your skin out and your look like a lepper for days. have always used it for alloy wheels, found nothing better.
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 187 ![]() ![]() |
Iron-X - Nothing more needed !
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 555 ![]() ![]() |
Iron x is very good but it only removed what it is designed for, so will still need a tar remover. Steam cleaner if you have one in the home.
Then plenty of elbow grease. |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
I've always used caustic soda and water in a mister.
Just don't breathe in when doing it! |
Or use TriX ![]() http://www.cleanyourcar.co.uk/engine-and-e..._1033.html |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Looks good. cheers all.
Trix look like the ticket ![]() |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Been using Wonder Wheels for years. Expensive, but damn good. Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134 ![]() ![]() ![]() |
Autoglym Cleen wheels for brake dust and general grime, tar remover for tar and over sprayed wax oil worked for me Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
Crikey it's not that quick at eating rubber. Use WD40 to clean the rims and wash off afterwards. Incidentally that is also why all wheel cleaning products say to wash off thoroughly, they contain some strong stuff... |
I've tried lots of different ones, I now use the halfords alloy wheel cleaner, you can buy a gallon cheap enough and pour into a window cleaner spray bottle, it's acidic so much be washed off the tyres
