|  | Home > Maintenance & Modifications > Cleaning alloys? what to use? |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501      | Concrete cleaner from one of the big DIY chains gets baked on brake dust off.
 As a normal cleaner i use Quantum alloy wheel cleaner from VW,s trade parts outlet TPS,works a treat. 2005 Td5 90 XS Steve | ||
|  22nd Sep 2013 5:58pm |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410    | WD40 works well, as does Autoglym Clean Wheels    | ||
|  22nd Sep 2013 6:01pm |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328    | Just remember WD40 eats Rubber    so thats your valve gone and your black round rubbery things | ||
|  22nd Sep 2013 6:05pm |
| mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143      | neat TFR, traffic film remover, use gloves as it drys your skin out and your look like a lepper for days. have always used it for alloy wheels, found nothing better.     LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE | ||
|  22nd Sep 2013 6:07pm |
| Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 188    | Iron-X - Nothing more needed ! | ||
|  22nd Sep 2013 6:27pm |
| a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 555    | Iron x is very good but it only removed what it is designed for, so will still need a tar remover. Steam cleaner if you have one in the home.
 Then plenty of elbow grease. | ||
|  22nd Sep 2013 6:31pm |
| Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479    | I've always used caustic soda and water in a mister.
 Just don't breathe in when doing it! | ||
|  22nd Sep 2013 6:33pm |
 Or use TriX   http://www.cleanyourcar.co.uk/engine-and-e..._1033.html | ||
|  22nd Sep 2013 6:43pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Looks good. cheers all.
 Trix look like the ticket  | ||
|  22nd Sep 2013 7:36pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | Been using Wonder Wheels for years.  Expensive, but damn good. Craig Rogers
 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  22nd Sep 2013 7:57pm |
| skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134      | Autoglym Cleen wheels for brake dust and general grime, tar remover for tar and over sprayed wax oil worked for me Series IIa Lightweight - Long Gone
 Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility | ||
|  22nd Sep 2013 8:00pm |
 Crikey it's not that quick at eating rubber. Use WD40 to clean the rims and wash off afterwards. Incidentally that is also why all wheel cleaning products say to wash off thoroughly, they contain some strong stuff... | ||
|  22nd Sep 2013 8:10pm |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | I've tried lots of different ones,  I now use the halfords alloy wheel cleaner, you can buy a gallon cheap enough and pour into a window cleaner spray bottle,  it's acidic so much be washed off the tyres    | ||
|  22nd Sep 2013 8:20pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      |  | ||
|  22nd Sep 2013 8:33pm |
| Posting Rules
