![]() | Home > Maintenance & Modifications > Cubby Boxes |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17952 ![]() ![]() ![]() |
I made a unit to hold a subwoofer that sits under the cubby, between the cubby and seatbox. Works for me, maybe something similar might work?
I didn't want to put the sub on the back of the cubby since it would prevent the rear seats (it's a 110 DC) from tipping forward. |
I have a lok box on my 110, well made and would easily accommodate an amp either under or on the back
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
Many thanks, In my ideal world I would be fitting an MSS cubby. Need to have a look at it properly when I get back to see what my options are.
Will have a search for lok box and see if that suits my needs 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
If the AMP is plug & play, then perhaps you could get an extension cable made up, then just "move" it to somewhere more suitable... under the middle seats?
That may be a solution Jamie. I can't see it being anything other than plug and play really, it a LR afterall 110 D250 SE HT
Shep Member Since: 02 Sep 2013 Location: Pwhelli Posts: 95 ![]() ![]() |
Mine has a subwoofer next to the battery under the passenger seat, seems plenty of room in there, i bought the set as it is it so i'm not to sure if its had stuff moved from there. A man with no boat is a prisoner
Not kowing how much room is under the seat I can't comment. But I do know from pics that I've been sent the amp is quite big and it looks like the LR cubby is a shortened version to make room for it.
![]() Hence all the issues I'm having. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
gbmud Member Since: 02 Jun 2013 Location: Sussex, UK Posts: 167 ![]() ![]() |
Might the sub fit in a MSS cubby? Do you know how big the MSS cubby is? Do you want the sub dims.?
Chris
I have a feeling this is going to be an ongoing project for when I get back. I have no idea of the internal dims of a MSS cubby or if there is a way to mount the amp inside without causing heat issues. I had hoped it would be a simple upgrade and I could order it in before I returned home. Why is nothing in life simple??? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Assuming that they MSS cubby box has not changed in dimensions since I bought mine way back, then the internal dims. are 245h (200h with oddment tray in place) x 240w x 305l aperture - since the front slopes the bottom of the box ix slightly longer. The Alpine sub in my 110 is 120 x 280 x 215 so I think the sub would fit inside the MSS box if it were flat on the bottom or against one side. Not ideal, but having looked I do not think it would fit easily under the second row seats.
Chris |
Reckon I might be able to glue some string together if I can get the plugs. |
That will be good Jamie. Will let you have a look when I get home.
![]() ![]() Could even relocate a bit further if needed then 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
try www.Barebox.co.uk , some nice solid ones there... Putting Dreams on Drives at JLR Solihull..
