Home > Puma (Tdci) > Random fault: Turbo probably?
Page 2 of 3 <123>
Eduardo
Laughing Laughing Laughing Laughing
Well, on saturday I deliver the car to an Indy to check the faults (together with the BAS thougths). According to him he check one sensor (I can hear quite well wich one due the noise in my office Embarassed ) that give erratic information outside the parameters and probably this will be the cause of the behavior.
He will check again with a new sensor the car tonigth to see if all working OK.
I will give you more info tomorrow.
Cheers! Eduardo
Post #267227 16th Sep 2013 4:56pm
Eduardo
Finally was the air flowmeter that given some erratic values...
Cheers and thanks to all Eduardo
Post #267408 17th Sep 2013 2:52pm
bell-auto-services
Glad you have it sorted Smile Thumbs Up
Post #267435 17th Sep 2013 4:48pm
Skye_Rover
Scotland 1998 Defender 110 300 Tdi CSW Cairns Blue
Great to hear that it is sorted Thumbs Up I am a bit surprised at the diagnosis, all the same, as your profile says that you have a 2.4Puma, not a 2.2Puma. Which means implicitly that you have a smoke-limitation strategy that is based upon air pressure (like an older "mechanical" Bosch system) not air mass. That means that your failure, if the smoke limitation was holding you back, would have had to be caused by an EGR incorrect operation leading to lower air pressure, or a failed boost pressure sensor. Both are not as likely as a failure in a true mass airflow control smoke limitation. So you truly have an enigma in your fleet!!! Roads? Where we're going, we don't need roads.
Post #267462 17th Sep 2013 6:49pm
Caterham
sorry what you said hasn't quite sunk in.....but.....
I beleive there's a mass air flow sensor and a mass air pressure sensor.
the MAP being at the junction of egr gas and fresh (intercooled) air just prior to the inlet manifold.
Post #267668 18th Sep 2013 1:46pm
dgardel
Italy
Glad you have it sorted Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #267676 18th Sep 2013 2:07pm
Caterham
I'm struggling today.....didn't realised it was sorted
Thumbs Up
that's Grrrrreaaat !
Post #267677 18th Sep 2013 2:11pm
Skye_Rover
Yes, that's the one that is primarily responsible for smoke-limitation fueling on the Puma 2.4 Visteon strategy. If it was a smoke-limitation problem you were experiencing, I believe that it would be that sensor that would have to be faulty, although there are some weird interactions from the MAF meter as well in determining the maximum permitted fuel. If the MAF has fixed the issue, then that is great, and one to file for future reference. Hopefully you will have many more hours of happy motoring! Roads? Where we're going, we don't need roads.
Post #267742 18th Sep 2013 8:58pm
Eduardo
Thanks to all,
After 500 km in almost all conditiosn during this weekend no problems arises.
For the records, the sensor replaced were the MAF.
Cheers! Eduardo
Post #268681 23rd Sep 2013 3:10am
Eduardo
Again!!!
Double posting Eduardo
Post #268682 23rd Sep 2013 3:12am
Caterham
thats great news.
happy motoring. Thumbs Up
Post #268820 23rd Sep 2013 5:03pm
Caterham
can anyone suggest costs for the MAP and MAF sensors ?
Post #269522 26th Sep 2013 9:16am
Eduardo
MAF cost me in Chile CLP150.000, equivalent to 186 GBP Eduardo
Post #269595 26th Sep 2013 4:19pm
dgardel
Italy
MAF in Italy costs 75€ (may be cheeper from Ford dealer?) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #269597 26th Sep 2013 4:32pm
Caterham
would both sensors be identical to those on a transit?
Post #269778 27th Sep 2013 3:54pm
Page 2 of 3 <123>
