![]() | Home > Puma (Tdci) > Random fault: Turbo probably? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() Well, on saturday I deliver the car to an Indy to check the faults (together with the BAS thougths). According to him he check one sensor (I can hear quite well wich one due the noise in my office ![]() He will check again with a new sensor the car tonigth to see if all working OK. I will give you more info tomorrow. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Finally was the air flowmeter that given some erratic values...
Cheers and thanks to all Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Glad you have it sorted
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
sorry what you said hasn't quite sunk in.....but.....
I beleive there's a mass air flow sensor and a mass air pressure sensor. the MAP being at the junction of egr gas and fresh (intercooled) air just prior to the inlet manifold. |
Glad you have it sorted ![]() ![]() ![]() ![]() IID Pro MV License |
I'm struggling today.....didn't realised it was sorted
![]() that's Grrrrreaaat ! |
Skye_Rover Member Since: 30 Aug 2013 Location: Skye Posts: 85 ![]() ![]() ![]() |
Yes, that's the one that is primarily responsible for smoke-limitation fueling on the Puma 2.4 Visteon strategy. If it was a smoke-limitation problem you were experiencing, I believe that it would be that sensor that would have to be faulty, although there are some weird interactions from the MAF meter as well in determining the maximum permitted fuel. If the MAF has fixed the issue, then that is great, and one to file for future reference. Hopefully you will have many more hours of happy motoring! Roads? Where we're going, we don't need roads. |
Thanks to all,
After 500 km in almost all conditiosn during this weekend no problems arises. For the records, the sensor replaced were the MAF. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Again!!!
Double posting Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
thats great news.
happy motoring. ![]() |
can anyone suggest costs for the MAP and MAF sensors ?
MAF cost me in Chile CLP150.000, equivalent to 186 GBP Eduardo
MAF in Italy costs 75€ (may be cheeper from Ford dealer?) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
would both sensors be identical to those on a transit?
