william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Gave her a wash after finishing the front end off getting some things painted.
![]() ![]() Click image to enlarge William |
Ideally both sets of nuts but the spacer nuts are really important. If they become loose they create some really interesting driving... ![]() |
It shouldn't be necessary to threadlock any of the nuts.
I discussed this with Rakeway when I bought mine, and they assured me that there was no point. I torqued the spacer-to-hub nuts, and (as always) the wheelnuts, and have never had any issues with then in 80,000 or so miles since fitting. The idea that the nuts will loosen seems to be like the myth that spacers will wreck your wheel-bearings - one of those popular fallacies which has suddenly become gospel since the advent of the Internet! |
cheers blackwolf - I will re-torque them at the w/e
I've never had an engine blow up in 1,000,000 or so miles but I don't doubt it's happened to others - anecdotal evidence is good for a warm feeling but hardly conclusive. Putting it the other way around - is there any harm to be done by using threadlock? Trying to understand what they meant by "no point" - are the bolts sandwiched so tightly by wheels that the nuts physically cannot loosen?
Wheel spacers will change the loadings/load paths through your hub. It's then a calculation as to whether the revised loadings still fall within original equipment design parameters. If all this is done then there should be no issue - however, which of the companies selling the spacers have done & can publish this information? To accept an assurance without any real evidence or third party certification seems foolhardy to me on such a safety critical component. |
Applied 4xDinitrol aerosol's (3125) to the inside of the chassis, X-members and around the seams of the floor and lower bulkhead,need s'moar now coz a ain't dun the doors or inner bulkhead,meh! Gently warmed the tins up in warm water before using,covers really well impressed with it.Also applied masking tape to some of the chassis and rear x-member holes to contain overspray and stop the "precious" from dripping on to the drive.
Probably not, but equally if there's no need there's no merit.
No, I suspect that they are working on the principle that a correctly tightened nut normally loaded seldom works loose. You don't use threadlock on your wheelnuts, the only difference with those holding the spacers on is that they are less visible.
Not by a singificant amount, unless you use an absurdly large spacer. Used on a Defender, 30mm spacer will have the same effect as a wheel with zero offset. The increase in static load on the bearings is probably less than the increase in static load cause by adding a passenger to the vehicle. If the design margins were really that small we would indeed be in trouble.
As a matter of interest, have you made any modifications to you Defender? |
Blackwolf - "Used on a Defender, 30mm spacer will have the same effect as a wheel with zero offset"
My take on this is a wheel with whatever offset will still have the loading via the hub/wheel mating surface. A wheel with a 30mm spacer moves this load path 30mm away. It cannot be said that they are the same. ![]() Click image to enlarge Is the effect at the black dot the same? Modifications - yep - particularly pleased with my umbrella mounts: [URL=] ![]() Click image to enlarge[/URL] :D Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Since the wheel and spacer are to all intents bolted together as a single rigid structure, the loading on the bearings is no different at all to that cause by a solid wheel with its centre 30mm further from the hub.
Since this has all been covered before, I will quote a post I made in the thread Best Spacers earlier:-
I hope you did a risk analysis of the behavious of your brollies in the even of an accident - wouldn't want one of those pointy killers loose in the car! ![]() (Actually I thought that was a rather nifty mod). |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Mine haven't fallen off yet, although I did put a bit too much copper grease on which went in a few places I didn't want due to centrifugal force
![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Just don't say I told you so when I report a punctured lung after heavy breaking. ![]() |
Loving the Foden in the background! Those were the days! ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Centrifugal force?! Blasphemy! There's no such thing ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
thank you for reminding me - I'd forgotten again
![]() http://regentsprep.org/regents/physics/phy...entrif.htm |
