Home > Pictures & Video > Light Reconnaissance Vehicle 400 (LRV 400)
"A militarized variant of Qt Services’ successful `Wildcat` off-road motorsport vehicle" so there might be some defender under there somewhere?
More here - http://defense-update.com/20130910_supacat...-2013.html
Possibly most interesting - "It can be fitted with a range of powertrain options – the display vehicle has a Ford 3.2-litre, 5-cylinder diesel engine developing 236 hp and 550 Nm torque coupled to a Ford-supplied 6-speed automatic gearbox and two-speed transfer box however, other engine and transmission options are available."
Post #265460 11th Sep 2013 7:28am
Caterham
i like it !
great stuff. Thumbs Up
Post #265466 11th Sep 2013 7:44am
theorangebandit
Shane the army won't buy it and they don't need it really the jackel isa brilliant recce vehicle
Post #265506 11th Sep 2013 9:03am
Not sure the British Army won't buy it, especially if it can go via the Urgent Operational Requirement (UOR) route but not seen any costings yet...
Post #265545 11th Sep 2013 10:08am
Glynparry25
No chance the British army will take it- probably aimed at 'foreign' armies.
The British army even cancelled the last batch of Jackals because they aren't what they want anymore- not enough protection.
Glyn Dog Sheep
Post #265565 11th Sep 2013 10:42am
Have you got any more info on the cancelled order? Not seen anything about that.
I'm hoping they do buy a few...as what goes in one end eventually ends up coming out the other at Withams Very Happy
and a little video here:
http://www.foxnews.com/tech/2013/11/12/arm...-brew-tea/
Post #265582 11th Sep 2013 11:40am
Mk II version released and it's now based on the Discovery rather than Wildcat.
The LRV 400 has the unique feature of being convertible from 4×4 to 6×6.
The LRV 400 has front and rear independent double wishbone air suspension offering variable ride height and lock out – bump stops for stable firing and high power to weight ratio.
Powered by a V6 3.0 turbo diesel providing 256 bhp and 600Nm Torque , it has an 8 speed automatic transmission and high and low permanent 4WD with centre diff lock.
Cross-axle diff locks are also available as an option.
https://vimeo.com/139381405
Post #454357 12th Sep 2015 9:21am
Now out and about.
Who needs a new Defender, when this ticks so many boxes?
Post #768423 13th Apr 2019 4:07pm
ibexman
What ^^^ he said
Post #768425 13th Apr 2019 4:34pm
Pilgrimmick
Look at the ramp break over angle, like a bus, will not get far without getting stuck. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #768446 13th Apr 2019 7:53pm
Ramp angle is 153°
Ground clearance is 180mm (loading) & 320mm (standard).
If that's you definition of a bus, I'm happy to drive a bus 😉
Post #768499 14th Apr 2019 7:42am
