![]() | Home > In Car Electronics > is the radio aerial electric |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5967 ![]() ![]() |
No it's not automatic.
The auto part of the ariel is that as soon as you see a bush or tree it will snap and fall off. Andy |
bcp Member Since: 01 Aug 2012 Location: East of Scotland Posts: 94 ![]() ![]() |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2020 ![]() ![]() ![]() |
sorry to hijack your thread anybody changed there areial?
its a bit old fashioned really, is it possible to hide it on the rear window like the rrs and disco's 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20906 ![]() ![]() |
You could always fit an auto one though if you wanted, relatively simple to do.
I never use mine so not fussed. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
.....as is the truck, so blends well in, no? ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
if you decide on an electric aerial, check the size and space available, i recall it might not be as straightforward as it sounds. if you do, please post up some photos
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
I went for the "cheap" upgrade suggested by another forum member.
Got one of these > http://www.ebay.co.uk/itm/270955002855?ssP...9106484653 Then extended the standard aerial out, cut it off quite low down, screwed in this new aerial into the exising one. Crimped it tight and pushed the remains of the standard aerial back in. Works a treat and looks so much better. I'll take a close up photo, but you can see it on this photo ![]() Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Agree the standard aerial is really naff but so far I've found reception with the aerial fully down to be good enough to get along with.
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
There is a company that sells an electric aerial where the motor is remote so it all fits in the space below the aerial hole. Std Electric Aerials As far as I know do not fit.
I did look at one of the electronic windscreen aerials but because the wipe area on the windscreen reaches near to the top of the screen it would have come into the visible area for MOT failure. I will try and find the link. Just remembered it's Mobile Centre. Here is the link: http://www.mobilecentre.co.uk/index.php?ma...cts_id=724 |
I consider the standard aereal to have an extremely valuable function.
Fully extended it is about 5 cm higher than the highest point of the 110 (the rear), so the aereal is acting as a warning signal for eventual height issues in underground parking lots. Would not want to miss it or replace it only for that reason already. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
alfred. Member Since: 25 Jun 2012 Location: Brindisi - Puglia Posts: 37 ![]() ![]() ![]() |
Nakatanenga have this:
http://nakatanenga-tours.de/shop/article_N...tenne.html DEFENDER 110 SW Puma 2.2 Corris Grey "ROKKO TORPES II" |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
I do exactly the same! I drive under a car park height thingy bar up to the aerial, see that I fit then gun it! Freaks the f**k out of passengers! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
How does that work, I swear my aerial which is standard (although on the
just did a quick google, they are 22 from amazon UK ![]() |
