Home > In Car Electronics > is the radio aerial electric
bcp
2013 Defender 110 Puma 2.2 USW Orkney Grey
Hi, just picked up my new 110 USW XS. Is the aerial powered? it pulls up manually but I wondered if it was broken.
Thanks, BCP
Post #264965 9th Sep 2013 9:10pm
landy andy
No it's not automatic.
The auto part of the ariel is that as soon as you see a bush or tree it will snap and fall off.
Andy
Post #264969 9th Sep 2013 9:15pm
bcp
Laughing thanks
Post #264973 9th Sep 2013 9:18pm
bear100
sorry to hijack your thread anybody changed there areial?
its a bit old fashioned really, is it possible to hide it on the rear window like the rrs and disco's 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #264979 9th Sep 2013 9:32pm
You could always fit an auto one though if you wanted, relatively simple to do.
I never use mine so not fussed. Laughing ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #264993 9th Sep 2013 10:05pm
ericvv
Post #265031 10th Sep 2013 5:03am
if you decide on an electric aerial, check the size and space available, i recall it might not be as straightforward as it sounds. if you do, please post up some photos
Post #265044 10th Sep 2013 7:21am
x-isle
I went for the "cheap" upgrade suggested by another forum member.
Got one of these > http://www.ebay.co.uk/itm/270955002855?ssP...9106484653
Then extended the standard aerial out, cut it off quite low down, screwed in this new aerial into the exising one. Crimped it tight and pushed the remains of the standard aerial back in.
Works a treat and looks so much better.
I'll take a close up photo, but you can see it on this photo
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #265061 10th Sep 2013 8:17am
Agree the standard aerial is really naff but so far I've found reception with the aerial fully down to be good enough to get along with. Surprised
Post #265199 10th Sep 2013 3:11pm
smb
There is a company that sells an electric aerial where the motor is remote so it all fits in the space below the aerial hole. Std Electric Aerials As far as I know do not fit.
I did look at one of the electronic windscreen aerials but because the wipe area on the windscreen reaches near to the top of the screen it would have come into the visible area for MOT failure.
I will try and find the link.
Just remembered it's Mobile Centre. Here is the link:
http://www.mobilecentre.co.uk/index.php?ma...cts_id=724
Post #265208 10th Sep 2013 3:24pm
ericvv
I consider the standard aereal to have an extremely valuable function.
Fully extended it is about 5 cm higher than the highest point of the 110 (the rear), so the aereal is acting as a warning signal for eventual height issues in underground parking lots.
Would not want to miss it or replace it only for that reason already. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #265221 10th Sep 2013 4:18pm
alfred.
Italy 2013 Defender 110 Puma 2.2 SW Corris Grey
Nakatanenga have this:
http://nakatanenga-tours.de/shop/article_N...tenne.html DEFENDER 110 SW Puma 2.2 Corris Grey "ROKKO TORPES II"
Post #265275 10th Sep 2013 6:53pm
Cheshire110
Eric
I do exactly the same! I drive under a car park height thingy bar up to the aerial, see that I fit then gun it! Freaks the f**k out of passengers! Cheers, David
Post #265319 10th Sep 2013 8:23pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
How does that work, I swear my aerial which is standard (although on the Censored quite a bit) is lower than my roof line!!!???? 1998 110 300Tdi White Hard Top
Post #265327 10th Sep 2013 8:34pm
just did a quick google, they are £22 from amazon UK Thumbs Up
Post #265333 10th Sep 2013 8:39pm
