![]() | Home > Puma (Tdci) > Viscous Fan vs Kenlow (Puma 90) |
| Bob Sheeley Member Since: 07 Jun 2011 Location: Inside M25 Posts: 18
Broke off and smashed the rad.
Have a Kenlow now but how easily does the old fan come off? Does it unbolt from the water pump stub easily or are special tools needed? Bob Bob Sheeley |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
That's damn unfortunate, but the concensus is usually to not change to electric. The standard rad size is fine too - Land Rover generally do build good cooling systems.
I believe the viscous unit is held on with a LH threaded nut, although the last time I changed one was on a Stage 1 V8 so I guess things may be different now 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks for the input - Bob Bob Sheeley
| All times are GMT |
