Home > Puma (Tdci) > Viscous Fan vs Kenlow (Puma 90)
Bob Sheeley
I'm sure there must be posts about this but I can't track any down. My Viscous Fan has just sheared off and has destroyed the radiator.
Should I consider changing for an electric fan?
Also, the standard rad seems fine; any upgrades needed here?
Thanks for any advice or comments
Bob Bob Sheeley
Post #152856 30th Jun 2012 12:08pm
Bob Sheeley
Vicious Cooling Fan - help please
Broke off and smashed the rad.
Have a Kenlow now but how easily does the old fan come off?
Does it unbolt from the water pump stub easily or are special tools needed?
Bob Bob Sheeley
Post #264005 5th Sep 2013 6:05pm
That's damn unfortunate, but the concensus is usually to not change to electric. The standard rad size is fine too - Land Rover generally do build good cooling systems.
I believe the viscous unit is held on with a LH threaded nut, although the last time I changed one was on a Stage 1 V8 so I guess things may be different now Confused Darren
Post #264016 5th Sep 2013 6:51pm
Bob Sheeley
Thanks for the input - Bob Bob Sheeley
Post #264028 5th Sep 2013 7:21pm
