![]() | Home > Maintenance & Modifications > Defender door cards - stop the flap! |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Good work. My door fractured in the exact same place. I reckon its because the doors don't always close properly due to the striker bar needing adjustment, meaning you have to slam the door. Mine got welded up and is fine now.
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 ![]() ![]() |
Good job. whats the trick to getting the door lock surround undone without breaking. And also what holds the door card along the top edge. I've been able to get the rest undone but got scared
![]() Mick |
If I remember correctly, when you lift up the lock catch there is a little horizontal slot in the surround, that lets you insert a flat screwdriver to prise it up and out. Dont forget to remove the door opener surround, the door handle and the window winder. The top of the card is held in more plastic presstud type fittings that allow you to just pop the door card off.
My door cards are off at the moment, so I could take some photos for you tomorrow? |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
equipe59...brilliant clean professional job.
With skills like that, if you lived next to me, I could keep you very busy, "practising yor skills"! Well done, Pickles. |
The trick to removing the door lock surround is a piece of 2x1 timber or similar approx 12" long, place the flat of the 1" side under the lowest point of the surround and hit the timber from beneath with a hammer.
Thanks for that info WarPig and Matt, I'll have a crack at it. I've got a little rattle in there, plus I haven't done the sound proofing in them yet.
What's the trick to getting the top edge of the card off, along the window edge. I'm assuming there is some form of retainers there. I'm in the middle of 'flattening' off the rear area to store my 4 Wolf packs that arrived today. Got lots of ply and carpet and 3 1 metre load rails to go in. Mick |
No secret there really, there are four (or five
![]() These are probably the easiest to remove and rarely break, just pull the panel away from the door starting at the hinge end at right angles rather than lifting the panel upwards if at all possible. |
Ahaa, I had tried previously and had taken both sides and the bottom off but got scared off when I saw the lock clip and also couldn't see anything along that top edge.
Thanks Matt, I'll have a go when I finish the current project. Mick |
