Home > Td5 > Squealing under load
Page 1 of 3 123>
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Need some input from the experts out there.
Last few weeks the 90 has been making some rattling noises which seem to come and go. Yesterday on a more extended trip a squealing noise began coming from the front. Can't pin point from exactly where.
Symptoms, under light load in any gear there's a screech, coasting nothing, heavy load nothing, change down to use engine braking and its just possible to get the screech briefly again. Rev engine in neutral - nothing heard
Thoughts were front prop shaft UJ's but no real vibration to speak of
Fan belt but all electrics seem fine and there's not much load on the electrical system, also replaced in January this year.
Turbo bearings but no loss of performance so far
Front diff has a slight weap from around the usual oil seal from diff to prop shaft coupling, haven't noticed any oil the floor so don't think it's that bad.
Power steering pump seems fine, no unusuall noise from lock to lock.
Last of the TD5's, 50000 miles on the clock, new clutch 10000 miles ago with uprated thrust bearing, regulary serviced, never had any real problems to speak of until now. 2007 TD5 90 Hard Top
Post #263610 4th Sep 2013 7:24am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Exhaust manifold warped?
Post #263612 4th Sep 2013 7:26am
landy andy
The squealing could be your exhaust manifold has warped. Check for the studs being loose/snapped, and sooty deposits at either end of manifold.
Andy
Post #263613 4th Sep 2013 7:26am
Re: Squealing under load
UJ's don't always vibrate, sometimes they really do squeel. a kind of cyclic squeel, as the thing rotates. try pumping some grease into them just to be sure.
Post #263616 4th Sep 2013 7:38am
Landlord
Interesting will check today - it is chipped so could be a possibility.
Will also double check UJ's Thumbs Up 2007 TD5 90 Hard Top
Post #263621 4th Sep 2013 8:04am
Martin 01
Having that same issue with mine.
Think the manifold is warped.
Mine to has been remapped.
Will be checking it this weekend.
Post #263850 4th Sep 2013 10:52pm
Another vote for a warped exhaust manifold, I'm afraid. Had the same on my wifes' old DII, twice! Darren
Post #263853 4th Sep 2013 10:59pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Can they be machined flat again or must you replace,just for future reference ! 2005 Td5 90 XS
Steve
Post #263854 4th Sep 2013 11:01pm
I think it depends how badly it's warped. We ended up with a new one as the manifold failed pretty catastrophically second time around, resulting in complete lack of power and a recovery home. Darren
Post #263856 4th Sep 2013 11:05pm
landy andy
It can be reskimmed and this is the recommended way, otherwise you fit new and it will warp, like the old one. Where as one that has already warped is less likely to again.
Andy
Post #263863 4th Sep 2013 11:17pm
Landlord
Think I've found the problem - warped manifold, thought I would have to check it with feeler gauges - didnt need too was quite obvious Shocked
Thanks for the replies, very helpful
When taking the manifold off there were 2 gaskets between manifold and head, presume that is normal ?
Post #266662 14th Sep 2013 4:51pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I had the same problem not long after I had mine remapped. Exchanged the warped manifold for a secondhand one from my indie that had been skimmed but also had the webs between the manifold branches ground out too. Apparantly this helps avoid further warping. 15 months on and still going strong. Smile 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #266728 14th Sep 2013 8:35pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
Same issue with my TD5. When I had mine sorted by MID Engineering they also fitted something from JE Engineering to aid cooling, was only £60 or there abouts. Strong people are harder to kill and generally more useful!
Post #266734 14th Sep 2013 8:57pm
Trossachs turbo
Scotland 2005 Defender 90 Td5 CSW Oslo Blue
If possible change studs to engineered type, suggest JE engineering,I had mine re skimmed new studs all ok,should only be one gasket
Post #266800 15th Sep 2013 8:37am
Landlord
Presume OEM gasket is made of two thin pieces of metal pressed together because two pieces came off !
Will be ordering new manifold and gaskets tomorrow Thumbs Up 2007 TD5 90 Hard Top
Post #266825 15th Sep 2013 10:04am
Page 1 of 3 123>
