![]() | Home > For Sale & Wanted > [Wanted] front brake pads holding clips |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Sounds more like the rear pad fitting kit you are explaining. Front ones are two springs that go over the pins.
Andy |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I just bought a set of EBC (Green) pads and they have a kevlar type pad on the back to prevent rattle. Haven't tested them yet, but never had rattle from the front pads...... sure it isn't the rear?
Glyn ![]() ![]() |
dwardu110 Member Since: 23 May 2013 Location: mgarr Posts: 35 ![]() ![]() ![]() |
At the rear I do have the anti rattle springs as these...
[url] http://i.ebayimg.com/t/TALBOT-ALPINE-HUNTE....JPG[/url] at the front I have the springs but since a bit soft I think they are not working properly.... older 110/90 used to have something similar to this at the front.... ![]() I need them for 2002 110 vented front calipers.... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Fronts should be like this:
![]() Click image to enlarge I just built these calipers up and fitted to my 110. the springs are fairly strong... enough to just push the pads off of the disc (Well, they did when there was no oil in the system... now it's bled up, I suspect not) |
Something like this: ![]() |
