Home > For Sale & Wanted > [Wanted] front brake pads holding clips
dwardu110
Malta 2003 Defender 110 Td5 CSW Tonga Green
I am looking for a set of front brake pads holding clips to stop the pads moving and rattle on our bumpy roads... I know that on older versions defender there used to be a sort of thin metal that was wedged between the pad and the holding pins.....sorry do not know how to explain it better....
any pointers?
Post #262806 1st Sep 2013 8:27am
landy andy
Sounds more like the rear pad fitting kit you are explaining. Front ones are two springs that go over the pins.
Andy
Post #262812 1st Sep 2013 8:43am
Glynparry25
I just bought a set of EBC (Green) pads and they have a kevlar type pad on the back to prevent rattle. Haven't tested them yet, but never had rattle from the front pads...... sure it isn't the rear?
Glyn Dog Sheep
Post #262816 1st Sep 2013 8:59am
dwardu110
At the rear I do have the anti rattle springs as these...
[url]
http://i.ebayimg.com/t/TALBOT-ALPINE-HUNTE....JPG[/url]
at the front I have the springs but since a bit soft I think they are not working properly.... older 110/90 used to have something similar to this at the front....
I need them for 2002 110 vented front calipers....
Post #262831 1st Sep 2013 10:02am
Fronts should be like this:
I just built these calipers up and fitted to my 110. the springs are fairly strong... enough to just push the pads off of the disc (Well, they did when there was no oil in the system... now it's bled up, I suspect not)
Post #262860 1st Sep 2013 12:38pm
Re: [Wanted] front brake pads holding clips
any pointers?
Something like this:
Post #262937 1st Sep 2013 5:31pm
