![]() | Home > Maintenance & Modifications > Mantec Rear Window Guard - Rivet or Screw |
| Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479
For those of you that have installed the mantec rear window guard did you rivet or screw it. The kit comes with screws but I'm wondering if rivets may be more secure and not rattle lose?
| StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246
Cheers, good timing I'm just about to install mine. Didn't realise they rattled. Did you just glue the screws or did you glue or seal anywhere else?
Cheers 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
I screwed mine and it took about two and a half years before it started to rattle. With mine I tweaked a few of the mesh bars with a screwdriver to slightly "kink" the panel which took out rattle quite successfully.
I used tech roofing screws for mine as I had a box left over from a job plus they've got a rubber washer that may or may not help with vibration rattles. |
Thanks, I have plenty of rubber washers so may give them a go. I didn't want to rivet mine either as I wanted the flexibility & ease of removal.
| davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888
Another vote for tech screws here, fitted our MSS rear window guard using those. http://www.yorkshireoffroadclub.net/
Just keep an eye on the length of the tech screws
I've seen tech screws but never used them. So, how do they work then do they screw in lke a self tapper or do they have a nut on the back?
They screw in like a self tapper and have the bonus of being self drilling so no need for a pilot hole. What I have done before now is use one to drill the hole, don't let it go full depth of thread if you're not sure of clearance, take it out and use a cut down one to fix your guard/whatever in the freshly drilled hole. You can often drill 4 to 5 holes with one screw and I've taken my guard off a couple of times and reused the original screws
Cheers for that. I'll give it some thought
| SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388
used the supplied screws for mine. several thousand miles off road Morocco, Pyrenees, Arctic etc - 1 rattled loose. Just tightened it
Sweet, cheers all.
| All times are GMT |
