Home > Maintenance & Modifications > Mantec Rear Window Guard - Rivet or Screw
Sockpuppet
For those of you that have installed the mantec rear window guard did you rivet or screw it. The kit comes with screws but I'm wondering if rivets may be more secure and not rattle lose?
Post #262622 31st Aug 2013 2:20pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
I screwed and glued (lock tight) mine, as the rattling was epic. Not anymore though!! Very Happy Strong people are harder to kill and generally more useful!
Post #262628 31st Aug 2013 3:11pm
StephenO
Cheers, good timing I'm just about to install mine. Didn't realise they rattled. Did you just glue the screws or did you glue or seal anywhere else?
Cheers Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #262648 31st Aug 2013 5:11pm
JWL
I screwed mine and it took about two and a half years before it started to rattle. With mine I tweaked a few of the mesh bars with a screwdriver to slightly "kink" the panel which took out rattle quite successfully.
I used tech roofing screws for mine as I had a box left over from a job plus they've got a rubber washer that may or may not help with vibration rattles.
Post #262652 31st Aug 2013 5:23pm
StephenO
Thanks, I have plenty of rubber washers so may give them a go. I didn't want to rivet mine either as I wanted the flexibility & ease of removal.
Post #262660 31st Aug 2013 5:37pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Another vote for tech screws here, fitted our MSS rear window guard using those. http://www.yorkshireoffroadclub.net/
Post #262662 31st Aug 2013 5:48pm
JWL
Just keep an eye on the length of the tech screws Whistle You only want thrm to go through one layer of the door Whistle
Post #262675 31st Aug 2013 6:34pm
StephenO
I've seen tech screws but never used them. So, how do they work then do they screw in lke a self tapper or do they have a nut on the back? Thumbs Up 2007 Defender Puma Tonga Green
Post #262708 31st Aug 2013 8:12pm
JWL
They screw in like a self tapper and have the bonus of being self drilling so no need for a pilot hole. What I have done before now is use one to drill the hole, don't let it go full depth of thread if you're not sure of clearance, take it out and use a cut down one to fix your guard/whatever in the freshly drilled hole. You can often drill 4 to 5 holes with one screw and I've taken my guard off a couple of times and reused the original screws
Post #262722 31st Aug 2013 8:26pm
StephenO
Cheers for that. I'll give it some thought Thumbs Up Thumbs Up 2007 Defender Puma Tonga Green
Post #262735 31st Aug 2013 8:46pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
used the supplied screws for mine. several thousand miles off road Morocco, Pyrenees, Arctic etc - 1 rattled loose. Just tightened it
Post #262736 31st Aug 2013 8:47pm
Sockpuppet
Sweet, cheers all.
Post #262750 31st Aug 2013 9:16pm
