![]() | Home > Td5 > Help! Engine cuts out at full throttle |
| HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173
Thanks! I will take it out tomorrow. /Hans |
| Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100
If the engine light is coming on there should be a code.
Yes you are right guys. I took out the ECU today and the number is NNN500020. Running some checks, I noticed that the fuel filter and its bracket became very hot. The engine was running for around 15 minutes at idling speed and I guess the temperature of the filter was 60-70 Centigrades (very hot to touch with your hands). The coolant gauge was just starting to move. It was the two pipes going forward that became hot. The two pipes aiming rearwards were cold. Is this normal behavior? /Hans |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Fuel filter getting hot on a TD5 is normal
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Thanks Bob.
I also took a video of what is happening. Never tried video and YouTube before so hope it works. &feature=youtu.be Hans |
| Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439
See diagram
Click image to enlarge 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
Have you checked your crank sensor? How quick does it restart? What is exhaust doing during running? Smoke? All norm? What's exhaust doing restart, or not restarting?
Andy |
Thanks for the fuel diagram. But I am not sure that I know how it works. Other than the fuel gets hot and is supposed to. Everything was much easier on my old MG TD
Hans |
I have not checked the crank sensor yet. What am I supposed to look for? After the engine light comes on and it stops it will not start again but cranks fine. I have to switch off and wait for a minute or two so that the glow plug light comes on. Then it will start fine. If I switch off when it is running normally I do not have to wait for the glow plug light. It will start immediately. I have not noticed anything unusual with the exhaust at any time. So I have not paid any attention to it. Hans |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
This sounds very much like a problem we had at work on a Mondeo diesel.
Now i,m no diesel expert and a mondeo and a Td5 are probably very different beasts but i will carry on anyway at the risk of getting shot down in flames by someone with far more knowledge than me. Said mondeo showed very similar symptoms to the OP,s defender,it would drive o.k until you put it under some load i.e going up an incline with quite a wide throttle opening then it would just stop as if you had switched off the "ignition" To cut a long story short it turned out to be worn injectors allowing to much fuel to return to the tank resulting in low fuel pressure in the rail but enough to let the engine run.When the engine demanded a lot of fuel the fuel pressure dropped below a pre determined limit (i think about 960 bar) in the rail and the ECU shuts the engine down as it thinks there is a fuel leak. After leaving the car for a few minutes the car would restart with a short amount of cranking and continue until the next large demand for fuel. We had the injectors rebuilt by a local diesel specialist and the car is now fine. 2005 Td5 90 XS Steve |
It being dirty so getting a
Andy |
If you look at my video you may notice that when the rpm is dropping down the Engine get a small "hick-up" at 900 rpm just before reaching idling speed.
It is something that I did not notice before these problems started. Do you think it is relevant? Hans |
No, I think mine does this
Andy |
When you take your foot off the gas the ECU will stop fuel being injected (this is all to do with emissions) until the revs approach tickover and will then will start to inject fuel to prevent a stall.At least thats my understanding of it. 2005 Td5 90 XS
Steve |
