| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
If I'd had that on Steve I'd have been saved from Waxy hair!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Finally finished off replacing all brake pipes with new copper ones and replaced the flexi pipes with new braided steel ones.
A few minor tweaks to the front flexi pipes as I wend for +2" inch extra for when I replace the springs with HD ones. So I used the plastic spring thing from the old flexi pipes and put it on the new ones. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179
Fitted Rammount Cupholders. I mounted the bases on the side of the cubby box with long extension arms. That should stop the kids whining about not having anywheree to put their Starbucks....
Click image to enlarge 2013 Aintree Green 110 Station Wagon SX |
Hope there is a drip tray being right above an amp ? 1999 Defender TD5 110
After finding the original OEM connectors for the radio, I got them plugged into the radio and and also re-wired the speakers into the original LR loom 1999 Defender TD5 110
Fear not - they are easy to relocate when in use. This is their not in use storage position. I also have window mounts that they can be relocated to..... 2013 Aintree Green 110 Station Wagon SX |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Some pics of the brakes: Freshly painted Click image to enlarge Click image to enlarge Old ones coming off (ex salisbury front axle, extra HD brakes. apparently designed for slowing 7 tonnes of 110 desert patrol vehicle!) Click image to enlarge Click image to enlarge Click image to enlarge Can you tell which side i've done yet? Click image to enlarge Click image to enlarge Might have time to get out this afternoon and finish the N/S. needs new bearings on that one as well. Got them all ready to go in. |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Nice job Jamie ( as usual It's what's under the skin that counts )
Although in the spirit of defender2 you should have sprayed them yellow or red |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Goog job, but..................
the salisbury brake should be better than standard..... or not? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Yes, in theory, but my 110 doesn't weigh anywhere near like what these brakes are designed for, and there's a couple of sticking pistons in them, so I thought i'd just rebuild some standard calipers (and I had a brand new set of vented discs) and swap the over.
I have some new seals, so I'll rebuild these salisbury brakes with them. Will probably sell them on; I have a second set of discs as well, so they'll be ideal for someone with a higher performance 90/110. I had these on my old 90 and they were awesome! especially with 35" tyres, no brake fade at all. |
| Offroad-Tec Member Since: 28 Jul 2012 Location: Damshagen/ Baltic Sea Posts: 58
Hello,
mounted the new Hi Lift brackets for the HD bonnet hinges. Markus Click image to enlarge |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Markus, is putting your high lift in that position legal in Germany? Best, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Seems a very impractical position - not the easiest position to lift a jack on and off and can only end in tears when not if the bonnet and/or wing get gouged...
@eric
Hello, I carry the hi lift in a neoprene bag, the base plate and the top clamp aren't mounted. On the photo you can see the "big" hi lift. I only carry the hi lift for offroad-use and for advertising, not for the ice cream shop. There are other possibilities to carry a hi lift, in the car with universal-brackets, on our roof racks with especially brackets, ..... In Germany you can carry the hi lift on such a bracket, because it's freight. In the neoprene-cover it is protected. Greetings -Markus |
