![]() | Home > For Sale & Wanted > WTD - Tdci 110 diff guards |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Looking for some diff guards for my tdci 110, not sure which types will fit so advice handy too.
The QT type ones look best, but may not be possible? Anyone have any going? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2489 ![]() ![]() |
I have a friend who makes em. Zinc plated for 30 a pair 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
Are those the circular type which tighten with a bolt at the top and 'clamp around' the front of the diff? They should fit a tdci 110 RHD I assume? Sounds good if they do! Do you have a contact? Where is he based so I can collect / arrange courier? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Don't waste your time with clamp on ones,, I run a Southdown front axle guard, with a OEC rear diff guard Or find some QT ones California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Can I have some help deciding whether or not it will fit mine? Where do I look for these bolt holes? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
The bolt holes Russ is on about, is for the rear diff guard,, 2 holes on the underside of the diff nose California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
This is the guard Russ has. YOu need to make sure you have the mounting holes on the side of the diff as I have artistically drawn on the image.
![]() The front diff is the same as other Defenders including the old Discoveries/Range Rovers. I will also second the comments on the 'clamp on' diff guards- they do as much damage as they protect from! Glyn ![]() ![]() |
Thanks for the help guys, I'll have a look in a bit and get back to you.
Mine is a '10 110 utility, SHOULD it have them? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
How much would you want for it? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Yes,, all my 110's have had them, 07 to 11 MY's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I will soon be getting rid of my clamp on guards for QT's too.
Am I correct in thinking that is a 110 diff above? If so I notice an extra seal on the pinion area which my 90 doesn't have?.... ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
My photo is of the rear diff on my MY13 110 DCPU.
Strange... Mine is a '10 110 as you know and it has NO bolt holes....
Are there any of this type of guard which don't require the bolt holes...? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
