Home > For Sale & Wanted > WTD - Tdci 110 diff guards
Cheshire110
Looking for some diff guards for my tdci 110, not sure which types will fit so advice handy too.
The QT type ones look best, but may not be possible?
Anyone have any going? Cheers, David
Post #260760 23rd Aug 2013 7:45am
Welshsurferdude
Wales
I have a friend who makes em. Zinc plated for 30 a pair 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #260761 23rd Aug 2013 7:46am
Cheshire110
Are those the circular type which tighten with a bolt at the top and 'clamp around' the front of the diff?
They should fit a tdci 110 RHD I assume?
Sounds good if they do!
Do you have a contact? Where is he based so I can collect / arrange courier? Cheers, David
Post #260762 23rd Aug 2013 7:51am
BigRuss
I have a rear wrap around QT diff guard going spare Very Happy
The reason it's going spare is becauses they changed the diff casing on mine so it can't be installed properly, if you have a look at your rear diff and see if there are 2 bolt holes on the LHS it will fit yours.
The diff has never been fitted. Russell
2011MY 110 XS USW Black
Post #260766 23rd Aug 2013 8:35am
TJ101
Don't waste your time with clamp on ones,,
I run a Southdown front axle guard, with a OEC rear diff guard
Or find some QT ones California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #260767 23rd Aug 2013 8:40am
Cheshire110
Can I have some help deciding whether or not it will fit mine? Where do I look for these bolt holes? Cheers, David
Post #260768 23rd Aug 2013 8:49am
TJ101
The bolt holes Russ is on about, is for the rear diff guard,, 2 holes on the underside of the diff nose California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #260775 23rd Aug 2013 9:31am
Glynparry25
This is the guard Russ has. YOu need to make sure you have the mounting holes on the side of the diff as I have artistically drawn on the image.
The front diff is the same as other Defenders including the old Discoveries/Range Rovers.
I will also second the comments on the 'clamp on' diff guards- they do as much damage as they protect from!
Glyn Dog Sheep
Post #260776 23rd Aug 2013 9:39am
Cheshire110
Thanks for the help guys, I'll have a look in a bit and get back to you.
Mine is a '10 110 utility, SHOULD it have them? Cheers, David
Post #260777 23rd Aug 2013 9:44am
Cheshire110
How much would you want for it? Cheers, David
Post #260778 23rd Aug 2013 9:44am
TJ101
Yes,, all my 110's have had them, 07 to 11 MY's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #260792 23rd Aug 2013 11:09am
Post #260834 23rd Aug 2013 3:35pm
I will soon be getting rid of my clamp on guards for QT's too.
Am I correct in thinking that is a 110 diff above?
If so I notice an extra seal on the pinion area which my 90 doesn't have?.... Confused ___\⭐️Lone|Star|State/___
____\We|Will|Win/___[/size]
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #260899 23rd Aug 2013 9:27pm
My photo is of the rear diff on my MY13 110 DCPU.
Post #260959 24th Aug 2013 10:47am
Cheshire110
Strange... Mine is a '10 110 as you know and it has NO bolt holes....
Are there any of this type of guard which don't require the bolt holes...? Cheers, David
Post #260963 24th Aug 2013 11:18am
