Home > Technical > Installing reversing camera
Page 5 of 6 <123456>
mikeh501
SGH wrote:
As promised here are few pics of the reverse I have on my 130 and ideal for above rear door on a 90 or 110
200 x 28 x 30 mm
4 x Night Vision LEDs
180° viewing angle
IP67 water rating
420 TV lines
PAL TV System
Multi-angle for custom view
Like that. Is it surface mount? What holes are needed?
Post #244765 18th Jun 2013 9:57pm
Greener78
2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
SGH wrote:
I have some of these cameras coming into stock this week and some of these monitors that hopefully fit onto the original interior mirror stalk but will know more when they arrive.
Simon
Simon, did you get these cameras in? If so how much do they cost?
Also how long would you expect it to take for installation?
Thx
Post #245472 21st Jun 2013 10:28pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Simon[/quote]
Thx[/quote]
I'd be interested in these too.
Any news?
Post #249511 6th Jul 2013 10:31am
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
And me Thumbs Up Life is one big adventure, that's why we have the vehicle for the journey.
Post #249525 6th Jul 2013 11:26am
Macpaul
Assuming this is a non-runner now, at least as far as MPS Trading is concerned?
Post #253888 27th Jul 2013 6:19am
mk1collector
Why not try pm'ing him?
Post #253908 27th Jul 2013 10:45am
dgardel
Italy
Simon
I'm interested in these too!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #254259 28th Jul 2013 11:05pm
Eduardo
I have one quite similar to this but still not installed, I have problems to decide the best location Sad
Not in the upper part due the blockade of the spare wheel); in the middle can be damaged and the only space available can be the rigth side inside the crossmember but I dont like to have it not centered...
Cheers! Eduardo
Post #254273 28th Jul 2013 11:56pm
chrisb
United Kingdom 2012 Defender 110 Puma 2.4 XS CSW Santorini Black
Here's mine. Hidden above the rear plate, below the plate light. I personally think its a really neat solution.
Slightly off centre, but I put it there so I could see the tow hitch. Takes a bit of getting used to the angle, but with it, I can get close enough to hitch the trailer on my own. (Trailer and contents weigh in pretty heavily, and arent really manouverable by one person!)
Post #255600 2nd Aug 2013 11:55am
landy andy
Does anybody run their rear view camera permanently whilst driving?
Would like two cameras one perm showing what is behind, and switching across to show tow hitch when revers selected. So do I need a monitor (want rear view mirror type) with single display but two inputs or a twin monitor?
Andy
Post #259833 19th Aug 2013 11:16am
It would be possible easily with it correctly wired. Would be useful to keep an eye on trailer load to the rear as well for example if anything was coming loose or jumping about in the rear. Ideally IMO if you wanted two cams you'd need two displays (of any type) even if you have the capability to do a split screen display it won't be much good IMO. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #259836 19th Aug 2013 11:26am
landy andy
Having a rear window grill, tinted windows, and now planning to install dog guard, the rear view mirror is not that much use. So a permanent display, that is just an electronic version of a standard rear view mirror would be ideal. But the ability to see the hitch, both for connection, and just for parking, would be ideal, but only required while reversing.
Some monitors have two very small displays, but would prefer a full mirror size display, that switches between the two cameras with reverse light/switch controlling this.
Andy
Post #259845 19th Aug 2013 11:52am
You could either have one constantly on and the other reverse switched only OR one on a switch on the dash (so it's not constant but can be) and the other on via the reverse.
Saying that why would you need two would one not be okay and switch between the two purposes? Or are we talking about different angles? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #259848 19th Aug 2013 12:11pm
udderlyoffroad
Andy
You can get them, they are intended for trucks:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...1183365071
This one is from a Hong Kong seller, so take with large dose of salt. Note that its intended modus operandi is to have one of the twin screens permanently showing one rear camera, with the other showing...a DVD! Obviously a responsible LR owner would never do such a thing. Am sure you could wire up the reverse signal input to a switch on the dash, so that you could have the 'trailer cam' on permanently when towing. Real trucks don't have spark plugs
Post #259849 19th Aug 2013 12:19pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
I have been foll owing this thread with interest.
I am now waiting for my 110 to arrive and would be very interested if one of the site sponsors (SGH or others?) could fit one of these systems. Mr. Green
If so, how much would it cost to have this done, please, since my ability with wiring begins and ends with a standard 13A plug?
Embarassed 1970 Series 2A 88"
Post #259868 19th Aug 2013 1:34pm
