![]() | Home > Technical > Installing reversing camera |
Greener78 Member Since: 18 Apr 2013 Location: Keswick Posts: 48 ![]() ![]() |
Simon, did you get these cameras in? If so how much do they cost? Also how long would you expect it to take for installation? Thx |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Simon[/quote]
Simon, did you get these cameras in? If so how much do they cost? Also how long would you expect it to take for installation? Thx[/quote] ^^^^^^^^^ I'd be interested in these too. Any news? |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 ![]() ![]() ![]() |
And me
Assuming this is a non-runner now, at least as far as MPS Trading is concerned?
Why not try pm'ing him?
I'm interested in these too!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
I have one quite similar to this but still not installed, I have problems to decide the best location
![]() Not in the upper part due the blockade of the spare wheel); in the middle can be damaged and the only space available can be the rigth side inside the crossmember but I dont like to have it not centered... Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
chrisb Member Since: 16 Aug 2011 Location: Dark Peak Posts: 25 ![]() ![]() ![]() |
Here's mine. Hidden above the rear plate, below the plate light. I personally think its a really neat solution.
![]() Click image to enlarge Slightly off centre, but I put it there so I could see the tow hitch. Takes a bit of getting used to the angle, but with it, I can get close enough to hitch the trailer on my own. (Trailer and contents weigh in pretty heavily, and arent really manouverable by one person!) ![]() Click image to enlarge ![]() Click image to enlarge |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6026 ![]() ![]() |
Does anybody run their rear view camera permanently whilst driving?
Would like two cameras one perm showing what is behind, and switching across to show tow hitch when revers selected. So do I need a monitor (want rear view mirror type) with single display but two inputs or a twin monitor? Andy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
It would be possible easily with it correctly wired. Would be useful to keep an eye on trailer load to the rear as well for example if anything was coming loose or jumping about in the rear. Ideally IMO if you wanted two cams you'd need two displays (of any type) even if you have the capability to do a split screen display it won't be much good IMO. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Having a rear window grill, tinted windows, and now planning to install dog guard, the rear view mirror is not that much use. So a permanent display, that is just an electronic version of a standard rear view mirror would be ideal. But the ability to see the hitch, both for connection, and just for parking, would be ideal, but only required while reversing.
Some monitors have two very small displays, but would prefer a full mirror size display, that switches between the two cameras with reverse light/switch controlling this. Andy |
You could either have one constantly on and the other reverse switched only OR one on a switch on the dash (so it's not constant but can be) and the other on via the reverse.
Saying that why would you need two would one not be okay and switch between the two purposes? Or are we talking about different angles? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 ![]() ![]() |
You can get them, they are intended for trucks: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...1183365071 This one is from a Hong Kong seller, so take with large dose of salt. Note that its intended modus operandi is to have one of the twin screens permanently showing one rear camera, with the other showing...a DVD! Obviously a responsible LR owner would never do such a thing. Am sure you could wire up the reverse signal input to a switch on the dash, so that you could have the 'trailer cam' on permanently when towing. Real trucks don't have spark plugs |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
I have been foll owing this thread with interest.
I am now waiting for my 110 to arrive and would be very interested if one of the site sponsors (SGH or others?) could fit one of these systems. ![]() If so, how much would it cost to have this done, please, since my ability with wiring begins and ends with a standard 13A plug? ![]() |
