Home > Maintenance & Modifications > Question? Regarding mains power INSIDE Land Rover.
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I have a cTec charger that I use to top up/recon the battery in my 90 via a permanent 12v socket. This works well, BUT the 90 lives outside all the year. Until now I pass a mains extension into the vehicle via an open vehicle and lock the vehicle with the key to disable the volumetric alarm.
Any suggestions for an external mains socket and plug for the extension lead that is small and unobtrusive that I could fit to get mains power to the battery charger while locking the vehicle with ALL alarms functioning. Any suggestions/links much appreciated. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #259290 17th Aug 2013 6:21am
I've seen caravan mains plugs mounted on the side if defenders
Or put one in a wing top with a cover
Post #259295 17th Aug 2013 6:39am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
There is a handy extension that goes in a towing socket (if you have one) and its available from the d3 section of the forum shop. That would do the job nicely.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #259305 17th Aug 2013 8:25am
WarPig
Post #259310 17th Aug 2013 8:54am
WelshGas
Thanks Warpig and djhutton. The problem with that is that the charger is then outside the vehicle and in the weather etc:. I do not have a garage but do have an external/weather sealed power socket. My idea was Mains lead to vehicle socket. Vehicle socket to a 13amp domestic socket in back of vehicle to plug charger in and be able to lock vehicle with all alarms on. The external caravan mains socket, mentioned by bpman, could work but tend to be fairly large and so the problem is where to put it, or is there something smaller and waterproof? Bow down LANDYWATCH
Post #259312 17th Aug 2013 9:02am
Happyoldgit
Any decent motorhome or caravan supplies / accessories place will be able to supply a suitable socket which can be mounted somewhere tucked away or with an enclosure in which to house it that can be let into any flat panel.
http://www.ebay.co.uk/itm/CARAVAN-FLUSH-FI...258184bada
http://www.ebay.co.uk/itm/240V-CARAVAN-MOT...4ac3aafdca Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #259320 17th Aug 2013 9:20am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
If you look at Jasons build at this link (you may need to page down a bit) you can see how he put a mains connection to his 110.
http://forums.lr4x4.com/index.php?showtopi...amp;page=9
cheers
simon
Post #259324 17th Aug 2013 9:50am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Have you thought about putting the Ctek charger in a weatherproof box, running the Ctek extention lead to your vehicle and connecting through a 12s towing connector to your battery.
The caravan 240v plugs and sockets are not weather proof just splash proof. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #259345 17th Aug 2013 11:18am
WelshGas
Any thoughts about this? http://www.ebay.co.uk/itm/380642469662?ssP...1438.l2649
Could be fitted in the large hole in the rear cross member. The mains extension cable is already serviced by a very sensitive Earth Trip Detector and as it would be switched on after connection should be safe? Although I can wire plugs etc: I'm no qualified electrician. Whistle LANDYWATCH
Post #259361 17th Aug 2013 12:32pm
VeeTee
Netherlands
I fitted a "Binder Connector" to the rear (visible above the number plate light) for the mains supply. Inside the vehicle a ground fault interrupter, inverter and battery charger.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #259375 17th Aug 2013 1:53pm
WelshGas
That's it VeeTee. Do you have a link to where you sourced it? Been looking on-line but have yet to find the same plug and socket. Any info much appreciated. Thumbs Up LANDYWATCH
Post #259379 17th Aug 2013 2:19pm
WelshGas
Found the makers site [url] http://www.binder-usa.com/products/partsdetail/88689[/url]. Might try the eBay item in the meantime. Thumbs Up LANDYWATCH
Post #259392 17th Aug 2013 3:30pm
VeeTee
Netherlands
I bought the connecter in a yacht chandler here in The Netherlands.
Here is the UK website: http://www.binder-connector.co.uk/ Cheers, Vincent
MySite
Post #259394 17th Aug 2013 3:36pm
WelshGas
Thanks VeeTee, unfortunately it is not a retail site and their retail partners do not seem to have all the parts in stock. Will phone one of them on Monday. Thumbs Up LANDYWATCH
Post #259405 17th Aug 2013 4:20pm
VeeTee
Netherlands
WelshGas,
You can buy a complete set at https://shop.landreiziger.nl/230-volt-voertuig-aansluiting.html , they will send to the UK. Send an email to Martin from Landreiziger if you have questions, they speak English and their service is excellent! Cheers, Vincent
MySite
Post #259410 17th Aug 2013 4:54pm
