![]() | Home > Technical > Transmission Fluid Weeping -easy fix? |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
If it is indeed hydraulic fluid then the clutch slave cylinder seals are the likely candidate, to get to the cylinder on a Puma means a gearbox out job. I would check the fluid level in the clutch master cylinder reservoir and monitor accordingly. Sure it's not oil? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489
It could be the clutch slave cylinder which is inside the bel housing somewhere and requires the gearbox removing to replace. So definitely get it done under warranty whilst you still have it.
Regards, Mark |
DOH! Beat me too it. |
| Vizsla Member Since: 18 Nov 2012 Location: Berkshire Posts: 96
Thanks both
Just did a bit of reading up on this after you posted and it certainly sounds like it is unfortunately the CSC. Its definitely not engine oil (too clear and not viscous enough). What a pain if its gear box removal time and with so little mileage Its going to the dealers this afternoon now, which is only a few miles away, so they can get it up on their lift & take a good look. I'll feed back what they say. Good job I spotted it while still under warranty I suppose. Paul |
Guy Salmon at Ascot were extremely helpful and have calmed my fears of a transmission fluid leak - it was in fact condensate from the air con Apparently the AC vents above the gear box housing and was dripping exactly around the point at which the two bell housing halves meet and looks just like a leak when its just a small amount. Having run the air con fully on for a half hour journey and reinspected there is a lot more fluid (obviously) now dripping around that point and its clearly water not oil. Few!! Time to now get on with protecting the underside as intended and say sorry to 'Ermintrude' for doubting her reliability |
